09-14-2022, 09:56 PM | #1 |
Distributor Question
While troubleshooting why my '30 Coupe suddenly stopped running when idling, I noticed a dark black spot in the distributor rotor where it contacts the carbon button in the cap. I suspected arcing, but the spot polished off using Scotchbrite and there were no signs of arcing. The carbon button in the cap seemed shorter than I would have expected - about 1 mm beyond the raised bakelite area surrounding it.
A few questions, please: - Does this button wear, like brushes in a motor? - Is the black spot a normal condition? - How much should the carbon button extend beyond the area immediately surrounding it? Thanks, Mike |
09-15-2022, 04:16 AM | #2 |
Re: Distributor Question
Yes this button wears down. Sometimes people never check them and the rotor arm spring starts wearing down the brass surround of the button - Is the black spot a normal condition? Never seen a black spot , but often see a shiny spot where button seats onto the rotor arm spring. Like you, if black spot present I suspect possible arcing. - How much should the carbon button extend beyond the area immediately surrounding it? About 2 mm ( 1/12 of an inch in your fractional terms!) here's a picture of a brand new unused one Last edited by johnbuckley; 09-15-2022 at 05:24 AM. |
09-15-2022, 07:38 AM | #3 |
As usual John is spot on, when you reinstall the cap make sure the rotor pushes back on the cap, the rotor spring can be bent up so to make a positive connection
09-15-2022, 08:27 PM | #4 |
Thank you much for your prompt responses. Mike |
