08-26-2022, 10:38 AM | #1 |
Expert Opinion
I've got a 1/4 piece of plate steel that fits just about perfect across the intake deck of a flathead and covers the middle most 4 bolt holes. Do you think IF I add a lifting eye in the center of the plate would those 4 bolt holes be strong enough to use to lift a complete flathead withour stripping the threads??
08-26-2022, 10:48 AM | #2 |
Re: Expert Opinion
I'm no expert, but when I was a kid, we'd pull 'em out with a chain between 2 intake manifold bolts. (The links on our chain were just a little too small to put a headbolt through.)
08-26-2022, 10:51 AM | #3 |
Re: Expert Opinion
You'll be fine. I do it all the time.
Wayno
Life is not a spectator sport. |
08-26-2022, 11:03 AM | #4 |
Re: Expert Opinion
Thanks for the reassurance, Guys!!!
08-26-2022, 11:31 AM | #5 |
Re: Expert Opinion
2 intake bolts and a chain has always worked for years. If you have one of those "load levelers" it's even easier. Tensile strength of a grade 5 3/8-16 bolt like those used on intake is over 9000 pounds. Wish you lived closer to me, it would be fun to help you.
https://hiawathafasteners.com/produc...-hex-bolt-zinc |
08-26-2022, 11:39 AM | #6 | |
Re: Expert Opinion
Bolts is my business, I was not concerned with the bolts end of it, more so the block casting and thus "figured" 4 is better than 2......but just wanted a little reassurance of what I figured!!! Thanks, i wish we were closer too, I'm on an Island up here, ALL alone with my V8's!!! By the way, according to my torque and strength charts....Grd 2 is 74,000 tensile strength, Grd 5 is 120,0000 and Grd 8 is 150,000, L9's are 180,000. Just a little more for Grd 5 Proof load is 6600 and clamp load is 4950 FYI according to my charts!!!! "NC" or Course thread of course!!!! Last edited by rockfla; 08-26-2022 at 12:05 PM. |
08-26-2022, 12:16 PM | #7 |
Re: Expert Opinion
19Forty
Not sure exactly how the link you posted came up with 9000Lbs tensile unless they are taking into account the Dia X Lenght to figure somewhat less than "per square inch"???? Here is the chart I have use for 25 years and has been around here since way before my time AS RB&W has been out of business since the mid 70's!!!! HOPEFULLY Petehoovie will expand this for anyone who would like a copy!!!! Last edited by rockfla; 08-26-2022 at 12:26 PM. |
08-26-2022, 11:17 PM | #8 |
Re: Expert Opinion
I've pulled a bunch of engines with the chain/ intake bolts method. I alwys use allen cap bolts. have never bent or broken one.
08-26-2022, 11:29 PM | #9 |
Re: Expert Opinion
Robert,
I use four bolts, one each in the corners, which is probably more stable than using four in the center of the manifold area, in concert with one of those levelers. The latter is pretty much mandatory when installing a engine/transmission assembly into a '32 chassis with its firewall in place given the severe angle required to clear the front cross member and the bottom edge of the firewall at the same time. |
08-26-2022, 11:38 PM | #10 | |
Re: Expert Opinion
08-27-2022, 06:09 AM | #11 |
Re: Expert Opinion
Dont we need pictures with this thread???.......just sayin!
Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
08-27-2022, 08:27 AM | #12 |
Re: Expert Opinion
I always use 4 intake area bolts. One of the "leveler bars" really does help as you can change the angle during the different "phases" on installation/removal.
08-27-2022, 09:06 AM | #13 |
Re: Expert Opinion
I seconded the Engine load leveler, just be sure to get one with VERY fine threads. The one I got from O'Rilies was so coarse that I had to grease the threads to get it to work. Also get one with a removable or hinged hand crank. When I tilted the engine and tans enough to get it in my '36, I could not turn the crank.
Steve in Denver |
08-27-2022, 09:22 AM | #14 |
Re: Expert Opinion
When you consider the strength of a grade #5 bolt, it doesn't make sense to use ARP Head bolts.
Gramps |
08-27-2022, 10:00 AM | #15 |
Re: Expert Opinion
petehoovie: I stand corrected. You are correct.
https://www.almabolt.com/pages/catal...oadtensile.htm |
08-27-2022, 11:23 AM | #16 | |
Re: Expert Opinion
08-28-2022, 09:20 PM | #17 |
Re: Expert Opinion
We had this discussion about a boat trailer that lost an axle. Guess a leaf spring bolt was lost. Someone said you need a stronger bolt like a grade 8. Well that would be ill advised in my thinking. Grade 8 has very nice tensile stretch like headbolts. But are very unforgiving with forces that attack the bolt with sear force, like a flywheel or shackles. Better that they would bend verse break.
I like arp bolts. Pretty much can count on what you get. Not saying there are smart options that do work great. Nor would i buy a set to pull a motor. Put one together...yes Have a pittsburg 3/4 leveler pictured first above. Works great for what I need. Doesn't bind. Last edited by Tinker; 08-28-2022 at 10:22 PM. |
