07-24-2022, 12:07 PM | #1 |
Rear spring replacement
I am about to put a new rear spring in and I have always disconnected everything because I was removing the complete rearend. This time I just want to change the spring so if I remove the wheels and disconnect the shock links will the rearend drop down enough with the brake rods still attached to sneak out the spring? I know if I try this I will have to unbolt the anti-rattlers as well. Just wondering. The brake clevises are a bit of a pain in the butt. Thanks for your opinions, Marc
07-24-2022, 12:15 PM | #2 |
Re: Rear spring replacement
no the brake rods will have to be undone at the axle end. and the antirattlers unbolted as well.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
07-24-2022, 02:17 PM | #3 |
You still need a spring spreader to remove the shackles.
07-24-2022, 02:29 PM | #4 |
I have a spreader I got that covered. Thanks
07-24-2022, 02:30 PM | #5 |
Tom Endy http://www.santaanitaas.org/wp-conte...ear-spring.pdf |
