Old 07-14-2022, 10:04 AM   #1
DelPercio
Default Gas tank
Am not confident with my fuel gauge. Would like to make a stick with inches. Would I hit the float sticking it, do you put anything on the stick to see the fuel level and how many gallons per inch
DelPercio is offline   Reply With Quote
Old 07-14-2022, 10:37 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Gas tank
Use a dowel etc for stick won't hurt float. I used some flat stock aluminum etched in amounts
www.whidbeymodelaclub.com
Old 07-14-2022, 10:37 AM   #3
ursus
It helps to know what year of tank. The 28-29 tanks will measure differently than those of 30-31 model years. Somewhere in the Fordbarn archives is an entry describing a measuring stick made of wood dowel and the corresponding inch levels per gallon of fuel specific to the 30-31 Ford tanks.
ursus is offline   Reply With Quote
Old 07-14-2022, 11:05 AM   #4
katy
katy's Avatar
One could drain the tank, add a gallon at a time and make corresponding marks.
Old 07-14-2022, 12:13 PM   #5
Alwaysamopar74
Question on why everyone makes it complicated. Not being argumentative either. I filled my tank and used a wood dowel used to support small plants I stole from mama. Marked full.. then half..then quarter tank. Just using my eyes to divide the areas on the dowel. It's only 3/16s in diameter and lays in my rumble seat rain gutter just fine. And as my working gas gauge moves (gas being used) I've verified it with dowel. Fairly accurate.
Alwaysamopar74 is offline   Reply With Quote
Old 07-14-2022, 12:19 PM   #6
old ugly
old ugly's Avatar
i cut notches. if it is just you using it you will remember
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 07-14-2022, 07:47 PM   #7
Synchro909
Synchro909's Avatar
I trust my gauge all the way down to the bottom of the tank. When I install a gauge, I set the float wire to read ) when the float is on the bottom of the tank. Once the gauge reads ), I know I am close to walking. By yanking the steering wheel one way or the other and watching the gauge as whet fuel is left surges from one side to the other, I get a "fine tuned" reading. When I can't get any movement in the gauge, I have only a couple of miles left at most.
Why are you not confident with it?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-14-2022, 08:13 PM   #8
ModelAMitch
ModelAMitch's Avatar
I replaced my fuel gauge with a re-pop one and it seems to be fairly accurate. If the tank is a true 10gal, which I’ve read it is I think it’s on point. Rebuild kits are only a few $$ though if you want to keep the one you have.
ModelAMitch is offline   Reply With Quote
Old 07-14-2022, 10:02 PM   #9
gaylord degroot
gaylord degroot's Avatar
I've gotten pretty good by sound. Tapping the tank gives me a fairly accurate indication of the amount of fuel left.
gaylord degroot is offline   Reply With Quote
