02-23-2022, 06:27 PM | #1 |
Y Block Dampener install
OK, so I am onto the installation of my newly rebuilt dampener. I tapped the woodruff key, greased the snout of the crank and installed the pulley with a wood block. It went on fairly well for a bit then stopped. Now I know they are supposed to be easily installed but not supper tough either. What is the trick? Do I need to wail on it more? Do I need to tap the key down some more (probably will do that anyhow)?
I also assume that it should go in so the pulley will be flush with the snout where the bolt goes. Any help would be appreciated as I need to stuff the engine in two weeks. Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
02-23-2022, 08:26 PM | #2 |
Re: Y Block Dampener install
Did you try to bring it in with the bolt? If that is too short (damper not on far enough) get a longer bolt.
02-23-2022, 08:41 PM | #3 |
No, I just used a wood block and a mallet. Just don’t want to shear the bolt threads.
02-23-2022, 09:12 PM | #4 | |
. Last edited by dmsfrr; 02-25-2022 at 12:12 PM. |
02-23-2022, 10:13 PM | #5 |
it doesnt pay to pound on that.you can damage the thrust bearing.
02-24-2022, 12:59 AM | #6 |
I rented the tool for free at Auto Zone (or whoever it is that offers that service). Clean up the keyway and key itself, free of any burrs. Install the key deeply in the keyway, cocked at a slight angle from level. Apply a small amount of sealant around the key/keyway area to help prevent oil leaks. |
02-24-2022, 07:21 AM | #7 |
as has been said a longer bolt is the way to go.
02-24-2022, 10:50 AM | #8 |
Polishing the crank snout or honing the balancer bore is not what the factory had in mind. It's designed to be a tight fit and hammering it on can crack it in the keyway.
I learned on a 50's Cadillac engine, like an early SBC, they don't have a bolt holding the balancer on, they are a press fit. Heat the balancer to about 180 degrees in an oven. Put some mitts on your hands and one firm rap with a leather mallet and it's on. Under 200 degrees will not damage the seal or elastomer in the balancer |
02-24-2022, 04:53 PM | #9 |
There are tools that are specifically designed to remove/install Y-block damper; Casco has them. When I sent my 55 Tbird damper to Damper Dudes to be rebuilt, they commented that it was in better shape than most of the dampers they receive. Why? I didn't use a BFH to remove it. I won't use a BFH to install it either.
Having the right tools for the job usually makes the job easier. Tools aren't cheap, but using the right tool might put you money ahead in the long run. The Tbird dampers are not the same as other Y-block dampers and cost considerably more to replace. Last edited by 55blacktie; 02-25-2022 at 03:55 PM. Reason: syntax correction |
02-24-2022, 05:25 PM | #10 |
I always draw mine in with a longer,Grade 8, bolt and different washer(s) then near the end I install the final stock bolt.
02-24-2022, 08:48 PM | #11 |
I do the same
02-25-2022, 03:00 AM | #12 |
Ok. longer bolt it is. I will also make sure that the key is correct height and smooth. Would a hand held torch just on the barrel portion heat it up enough for it to expand and then use the bolts to draw it in?
Thank you, Mike By the way what is CASCO?
02-25-2022, 09:08 AM | #13 |
I never had to use a torch, and have done dozens as explained in my above thread.
02-25-2022, 09:45 AM | #14 |
Classic Auto Supply Company. They sell parts for, repair and restore '55 to '57 Thunderbirds.
https://www.classictbird.com/ . Last edited by dmsfrr; 02-25-2022 at 09:53 AM. |
02-25-2022, 05:06 PM | #15 |
A torch works, just be gentle. It's no different than using a rod heater instead of a press to install non floating wrist pins.
Pulling a balancer on with a bolt, if the crank is drilled, works better if you use a king pin thrust bearing along with the flat washer. Just remember this, any balancer can crack in the keyway if the interference fit is too tight. |
02-25-2022, 05:10 PM | #16 |
The keyway on those is a real tight fit in the keyway slot. If the key is slanted a little too much and the key isn't all the way down in the slot, the damper will bind up on the way down. I always liked to get the key slanted just a tiny bit so that the slot in the damper will clear the top of the key with ease, then force the key to straighten out as the damper goes down. I wouldn't use a hammer to bash the damper down. I always had a little bit longer bolt to get it started down, then I would take the bolt out and add bunches of oversized washers to drive it damper the rest of the way home. Be careful not to strip the threads inside the crankshaft.
