01-29-2022, 05:18 PM | #1 |
What is this for?
I have a EAB block. It has a grease fitting on the drivers side- just above the oil pan- about 6" from the back of the block. What is it for??? What would need to be greased when all that oil is in there??? Jerry
01-29-2022, 05:37 PM | #2 |
Re: What is this for?
Sounds like what should be the filter return line. Temporarily blocked with a grease zerk for storage?
01-29-2022, 06:00 PM | #3 |
CAS3 has got it - somebody grabbed a zerk fitting to block the 1/8 NPT oil filter return line hole.
01-30-2022, 02:38 PM | #4 |
