01-21-2022, 02:24 PM | #1 |
crank journal bolts
is there a special tool for the square haed on the crank journal bolt or can an 8 point socket work?
also I have pin holes in the dipper pan Im thinking I should braze them but has anyone ever used J B weld? |
01-21-2022, 02:59 PM | #2 |
Re: crank journal bolts
If I remember correctly, the square head is an uncommon size wrench, something like 25/32" I personally would not risk JB weld in the dipper tray. If it were to come free you'd risk catastrophic engine failure if it clogged a passage.
01-21-2022, 03:13 PM | #3 |
I think you'll find that the square heads on those bolts are the same as the drain plugs in gearbox and diff. They are the same as a plumbing fitting which makes sense when you consider the philosophy behind Henry's design and how he wanted every farmer to be able to work on his car.
I file them down to 1/2" and I've made a special tool that is basically a short socket extension wit a nut welded to the male end. The female end goes onto the reduced bolt head and an ordinary socket on the welded nut.
01-21-2022, 08:25 PM | #4 |
this was the era special wrench
there is a little pip on one corner of the square of the main bolts to show orientation of cotter pin hole on the other end to help line it up |
01-22-2022, 12:13 PM | #5 |
8 point socket works just fine, 9/16" IIRC.
01-22-2022, 01:24 PM | #6 |
I like that tool in the pics above going to try and braze the dipper tray seems like the best way to go on that |
01-22-2022, 06:17 PM | #7 |
I do believe I have a 4 point 9/16 socket I bought at a local industrial tool dealer like 25 years back.
01-22-2022, 06:31 PM | #8 |
I bought this tool from Amazon. Fits perfectly on those heads..
Square plug socket https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
01-22-2022, 06:46 PM | #9 |
Square head sockets are the best, great for engine work and adjusting brakes.
"The more things change, the more they stay the same." |
01-23-2022, 02:31 PM | #10 | |
thank you |
