11-07-2021, 02:15 PM | #1 |
Stall on incline
My 29 (with '28 engine) stalls when I am on an incline. This is Chicago so there are no hills. At very slow movement, as in parking, if I am on a bit of a slope the car stalls. I assume this is a carb issue. New fuel line, so that's not an issue. Any input?
11-07-2021, 02:22 PM | #2 |
Re: Stall on incline
Have you checked the float level?
11-07-2021, 02:55 PM | #3 |
Sounds like something I should check. Thanks.
11-07-2021, 03:23 PM | #4 |
crap around the base of the tank, where it feeds the fuel line.
install a pencil filter. |
11-07-2021, 05:33 PM | #5 |
front of the car facing up or down?
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
11-08-2021, 06:35 PM | #6 |
www.whidbeymodelaclub.com |
11-09-2021, 09:57 AM | #7 |
Check the screen in the carburetor. It's in the fitting where the fuel line attaches. You obviously have a restriction somewhere in the line. Check the sediment bowl, too. the originals can get rust and other crud that won't come out the drain hole.
11-09-2021, 09:47 PM | #8 |
Gas line in carb, to far in against screen restricting a good flow?
11-09-2021, 11:36 PM | #9 |
A restriction should also affect top speed so look at the float level first.
11-10-2021, 07:13 AM | #10 |
Did you get it fixed?
