10-18-2021, 01:45 PM | #1 |
Sticky brakes
Having sticky braking on my 49 with power brakes. Haven't taken it for a drive except for driving on the lift to work on it. What could be causing that?
41 woodie https://41fordwoodie.weebly.com/ |
10-18-2021, 02:09 PM | #2 | |
Re: Sticky brakes
What are the symptoms that you are calling "Sticky Braking"? . |
10-18-2021, 05:13 PM | #3 |
Re: Sticky brakes
If the shoes are not retracting, or retracting slowly, could be the flexible brake hose going to the wheel cylinders (front). With age they can collapse internally and act like a one-way valve.
10-18-2021, 05:31 PM | #4 |
Re: Sticky brakes
If I tap the brakes lightly they might lock up
10-18-2021, 07:56 PM | #5 |
Re: Sticky brakes
10-19-2021, 10:04 AM | #6 |
Re: Sticky brakes
10-19-2021, 05:10 PM | #7 |
Re: Sticky brakes
Disc front on fat man front end, drum rears on Ford 8 inch rear end.
10-19-2021, 06:30 PM | #8 |
Re: Sticky brakes
Piston in master cylinder not returning far enough to uncover port in master will lock them up. When they are locked if you crack a bleeder does that unlock them
10-19-2021, 07:18 PM | #9 | |
Re: Sticky brakes
I believe he is saying that just a short, light pressure on pedal CAN lock 'em up! DD . |
