Old 08-15-2021, 11:29 AM   #1
junkmanjr
junkmanjr's Avatar
Default 1932 Pedal Assembly
City: Knoxville
State: Tennessee
Price: 300
1932 Ford pedal assembly pretty good shape some pitting on base. Arms straight someone had added an extra catch for the mechanical brakes on the shaft could run them like that or cut it off. I assume they need bushings. $300 plus shipping
Alex 865-755-3114
junkmanjr is offline   Reply With Quote
Old 08-27-2021, 07:08 AM   #2
junkmanjr
junkmanjr's Avatar
Default Re: 1932 Pedal Assembly
Bump reduced to $250
Also to clear up any confusion or wonder The extra catch moves with the brake pedal and not the clutch arm. Yes the catch is welded to the shaft but there is also nearly a half inch gap between the pedal base and extra catch. So it would be pretty easy to make a clean cut. The shaft looks kinda long it was probably changed when they added the extra catch. Of course if you want to cut the extra catch off you can without hurting the pedals or base. A new shaft can be bought for a little under $30
Alex 865-755-3114
