05-14-2021, 05:03 PM | #1 |
new rear hub bearing failure
Do new rear wheel bearings have a failure with the end plates(thrust plates).
While looking for new bearings for my Model A sleeved hubs(uses '36-'48 Ford bearing ?) it seems as though it's a failure problem with the thrust plates (not hardened) and not the rollers. If you've replaced yours with no failure problems who was the supplier ? Don't want to go 500 miles like some have and bearings fail. |
05-14-2021, 08:34 PM | #2 |
Re: new rear hub bearing failure
Most often new means china. Find NOS or good used.
Bruce
Works good Lasts long time |
05-14-2021, 09:35 PM | #3 |
My searches for NOS have not shown any thing yet. I'll find them.I know there out there.
Your right. No China bearings. |
05-14-2021, 10:33 PM | #4 |
Even some German made bearings that I purchased new had soft end plates in the roller bearings. Always pays to check whatever brand you buy by touching the end plates with a fine file. You cant trust any particular brand these days. Ask THIRD GEN AUTO to send you some good new bearings. Regards, Kevin.
05-15-2021, 08:56 AM | #5 |
Or check with Fred at South Side Obsolete.
05-15-2021, 09:39 AM | #6 |
05-15-2021, 10:56 AM | #7 |
Looking on the swap side it look's like tudor 28 got his replacements. Hope he let's us know the source. I have a good used set if someone needs a pair as well.
