Old 02-25-2021, 09:27 AM   #1
wagonshed
Default '29 model A why does the light switch turn completely around in a circle
On my '29 model A pickup- why does the center light switch turn around in a complete circle and not work the lights? thanks. Jim
wagonshed is offline   Reply With Quote
Old 02-25-2021, 09:33 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: '29 model A why does the light switch turn completely around in a circle
It sounds like the light switch isn't in place at the bottom of the steering column .
Old 02-25-2021, 09:50 AM   #3
JBill
Like Purdy says. I'd guess the piece at the bottom of the rod is stripped or slipped out of place. If you loosen the bail and remove the wiring "bulb" thing at the bottom of the steering column you should be able to see what's wrong.
JBill is offline   Reply With Quote
Old 02-26-2021, 05:43 PM   #4
wagonshed
Thanks to both of you that responded, I'll check it out this weekend. Jim
