02-13-2021, 02:04 PM | #1 |
Ultrasonic cleaner
Anyone use an ultrasonic cleaner on carburetors or other small Model A parts?
02-13-2021, 02:53 PM | #2 |
Re: Ultrasonic cleaner
I do. I use it for soaking carb bodies in Evaporust, or brass parts soaking in clock cleaning solution.
Jim |
02-13-2021, 02:57 PM | #3 |
Yup. Depending on how dirty, it may take a few cycles. I used vinegar for the carb parts. Just make sure you rinse them off well after cleaning.
02-13-2021, 03:12 PM | #4 |
Unless you get one with heat, think they are pretty much a waste of time esp the ones sold by HF. Soak in Berrymen's carb cleaner, bead blast, clean good, paint and assemble.
https://www.walmart.com/ip/B-9-Chem-...hoCujgQAvD_BwE
02-13-2021, 03:22 PM | #5 |
I use it to clean pot metal carburetors. Use dish wash soap (liquid) in a beaker. Sonicate for 60 minutes at 40C. Does a great job. Don't know how it would work with a Zenith.
02-13-2021, 03:47 PM | #6 |
02-13-2021, 05:09 PM | #7 |
I use this one from Amazon. About 1.5 gal. Has heat and timer.
Plenty of room for most updraft carb parts. Did have to turn a large Stromberg carb over tho. |
02-13-2021, 11:50 PM | #8 |
I have a similar one from Amazon with the knobs instead of the digital controller. My first one was like yours but the read-outs quit working on about the third time I used it!
This new one works great on everything, I use Simple Green mixed with water at 50 or 60C and it does a good job! |
02-14-2021, 12:10 AM | #9 |
Great thread I’ve thought about getting one myself.
Those of you that have them may I ask why did you get the one you got? And would you get it again? I also second the size question too, I want to be able to do carbs in it. If a Quadra jet can fit in it then I’m good haha! |
02-14-2021, 02:33 AM | #10 |
Got one just big enough to hold a V8 Stromberg, with heat & timer. Does a great job, judging by all the muck in the bottom of the tank. Not done my A carb yet.
02-14-2021, 08:48 AM | #11 | |
Ive done a few carbs, plus some detail parts that would have been difficult to clean the crevices. Has worked well for me. |
02-14-2021, 08:57 AM | #12 |
I use one. Mostly with Simple Green Aircraft cleaner. Easier on aluminum parts.
02-15-2021, 07:06 PM | #13 |
I repair clocks for a living and it's a must for that trade. A heater is a must also. Works great on carbs and many other things also. To test- place a 2x2 inch square of aluminium foil in it. It should make it look like swiss cheese.
02-15-2021, 09:24 PM | #14 |
We have a big one at the shop for doing Porsche engine halves and cylinder heads. Another trick is to plumb a small submersible pump to the fuel inlet and circulate while cleaning.
