12-10-2020, 06:14 PM | #1 |
Cadmium Plating
I’m wanting to clean an redo the heater hose brackets on my 40 deluxe. I’m assuming that they were cadmium plated originally. Is there a spray paint that simulates the cadmium plating and looks correct? These brackets were reproduced but all the vendors are out of stock. Looking for suggestions.
12-10-2020, 06:23 PM | #2 |
Re: Cadmium Plating
Ken I use silver grille paint from Lowe’s. Can’t remember brand but will let you know. I like it for bolts etc.
12-10-2020, 06:25 PM | #3 |
Re: Cadmium Plating
Ken if you aren’t in a hurry send them to me and I’ll have them plated in our next batch of cadmium.
12-10-2020, 07:17 PM | #4 |
Re: Cadmium Plating
Dayum! I mean.....does it get ANY better? DD
12-10-2020, 07:54 PM | #5 |
Re: Cadmium Plating
test
12-11-2020, 09:57 AM | #6 |
Re: Cadmium Plating
Look for Special Purpose Krylon Metallic #1403 Dull Aluminum. Pretty close to the plating color. Hard to find as the last time i had to order it over the World Wide Web. |
12-11-2020, 10:23 PM | #7 |
Re: Cadmium Plating
I believe that Eastwood has something in a spray can that looks like what you want .
12-14-2020, 11:14 AM | #8 |
Re: Cadmium Plating
I use “VHT HIGH TEMPERATURE” flame proof spray. Fast dry,durable,looks like low sheen cad. I have used it on various bumper mount fittings, fog light fittings and such. Started using it as fast dry primer but found it looks better than the paint I wanted to use and have been using it ever since.
Frederic |
