09-14-2020, 04:03 PM | #1 |
NGK Plugs
Anyone using NGK plugs in an 8BA? if so any pros or cons?
09-14-2020, 04:21 PM | #2 |
Re: NGK Plugs
I'm using NGK's in my blown flathead with excellent results. They were recommended by some well known people here and so far so good. My 2 cents.
Joe |
09-14-2020, 04:45 PM | #3 |
Re: NGK Plugs
Me too. B6L in an 8BA style Merc slightly "warmed up". Plugs look just right. Milled 8CM iron heads.
Terry
09-14-2020, 04:59 PM | #4 |
Re: NGK Plugs
I have been using them for 15 yrs.
09-14-2020, 05:18 PM | #5 |
Re: NGK Plugs
B6L’s working good with my EAB heads.
Al |
09-14-2020, 06:06 PM | #6 |
Re: NGK Plugs
Thanks Andy 1952 F1 |
09-14-2020, 06:12 PM | #7 |
Re: NGK Plugs
Get them for Rock Auto for under $2.00 a piece
09-14-2020, 06:13 PM | #8 |
Re: NGK Plugs
Used for the past 15+ years in my 49
Henry Ford designed the flathead without the aid of a computer. |
09-14-2020, 06:16 PM | #9 |
Re: NGK Plugs
Lots of positives! Same plug you'd recommend for a stock 221?
09-14-2020, 07:12 PM | #10 |
Re: NGK Plugs
Yes
09-14-2020, 07:14 PM | #11 |
Re: NGK Plugs
Work fine on my 21 studder...
09-14-2020, 07:17 PM | #12 |
Re: NGK Plugs
NGK's are one of the only plugs where the electrode is indexed to the threads, if that means anything... I like 'em.
09-14-2020, 09:41 PM | #13 |
Re: NGK Plugs
I use the NGK GR4 2635 plugs recommended by Mark Kirby when I bought his heads in 1999.
Work fine. |
09-14-2020, 09:50 PM | #14 |
Re: NGK Plugs
Thanks guys! I am learning the value of a well tuned ignition system from the slot in the end of the cam to the tip of the spark plugs.
09-15-2020, 12:14 AM | #15 |
Re: NGK Plugs
The gold color on the threads is something sprayed on to help keep the plugs from sticking to the head so you can never strip the threads when removing the plugs. They break loose easier that way.
I just started using NGK plugs in 1972. I installed NGK plugs in my F1 in 2006 and again in 2016. |
09-15-2020, 06:29 AM | #16 |
Re: NGK Plugs
09-15-2020, 07:27 AM | #17 |
Re: NGK Plugs
Yes, B4L (3112) in my roadster.
09-15-2020, 07:57 AM | #18 | |
Re: NGK Plugs
09-15-2020, 02:13 PM | #19 |
Re: NGK Plugs
When RONNIE ROADSTER had my 40 this Spring that's what he installed. Runs great.
Paul in CT |
09-15-2020, 03:55 PM | #20 |
Re: NGK Plugs
