09-14-2020, 01:43 PM | #1 |
Wire Wheel Tires with Radisl tires
I know I need to seal the Wire Tires for leaks. Have any of you ever done this? That my next project to do. I did search on Google how to do this.
09-14-2020, 02:45 PM | #2 |
Re: Wire Wheel with Radisl tires
I sure did mess that up a bit. I know I should proof read but I don't. Wire Wheels leak air and need to be sealed. What the best way to do that. Tubes are a no no in Radial tires.
09-14-2020, 03:20 PM | #3 |
Re: Wire Wheel Tires with Radisl tires
I shouldn't jump in this, but, you know, there are radial tubes. You also need rim strips with tubes. The question I ask is why do you insist on radial tires in the first place? Bias tires would probably work just as well for your use. Bias ply tires are not bad, just different than radials. Each have good and bad features.
09-14-2020, 03:29 PM | #4 |
I got talk in to buying them so I got to make the best of it. Tubes are no good in Radial tires. On open highways they get very hot and blow up. I had that to happen to me.
09-14-2020, 04:06 PM | #5 |
If you're talking about the "Thunderbird" wires with the spokes out by the bead, I've never seen anyone claim to be able to seal them. I drove those wires with radials and the proper tubes for years, and never a problem.
09-14-2020, 07:25 PM | #6 |
I know some other Bird owners with the same set up - no problems with the tires/tubes. You have to run a liner to cover the spokes on the inside of the wheel. Best when mounting the tires with tubes is to use plenty a talcum powder on the tubes
09-14-2020, 07:47 PM | #7 |
Aren't there specially rated tubes for radial tires? To handle the additional sidewall heat...
09-15-2020, 05:57 AM | #8 |
That, I didn't know of. I'll try to Google that.
09-15-2020, 08:50 AM | #9 |
I google that and they said it a no no to put tubes in Radial tires. Glad to hear from you all. That how we learn.
09-15-2020, 09:03 AM | #10 |
I'll bet a years income the guy who wrote in Google that tubes in radial tires is a no-no is a young guy. Special radial tubes were used in heavy trucking for years in radials. I would recommend a call to Coker to answer the original question.
09-15-2020, 11:27 AM | #11 |
The Chevron gas station I worked at back in the early 70's had boxes with tubes for radial car tires on the shelf, next to the other tubes. Product types and availability have likely changed a few times since then....
. Last edited by dmsfrr; 09-15-2020 at 06:14 PM. |
09-15-2020, 02:28 PM | #12 |
Re: Wire Wheel Tires with Radial tires
Standard procedure in this day and age for running OEM Kelsey Hayes wire wheels for '62-'64 T-birds with radial tires is to use a radial tube (available from Coker), wrap the rim with 10 mil cushioned lineman's electrical tape 2"-wide to cover the spoke nipples (available at electrical supply store and maybe the big-box stores like Lowe's), and use lots of talcum powder when mounting.
If there was a heavy rim liner like what was originally installed on them I'd use them too, but they haven't been available for decades. If someone knows of a source for them (other than the guy in Seattle who's personal fifedom is the Sports Roadster Society), I'd sure like to know. I have NEVER trusted aftermarket wires that have been slugged full with silicone or other types of sealant over the inside face of the rim.
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
05-24-2021, 03:49 PM | #13 | |
05-24-2021, 05:17 PM | #14 |
"Tubeless" tires weren't designed to be used with tubes. Tubeless tires gradually lose air when punctured. Tubes pop like a balloon when punctured, losing all the air at once (not good). It was common (in the old days) to put a tube inside a tubeless tire that could not be plugged/patched, rather than replace the tire. I don't recommend it, but it's the only way you will keep air inside your tires/w spoke wheels.
05-24-2021, 08:25 PM | #15 |
I bought a set of True Spoke wires back in the 70s and they were sealed with what looked to be epoxy and fiberglass mat wrapped around several turns in the rim well. They always leaked. I eventually put tubes in them and they held up till I finally sold the car they were on. Coker sells radial tubes as well as some others. I think rim strips or flaps are still available to cover the spoke nipple ends. Tubes don't like rough spots to wear against. No tube can survive that kind of friction.
05-25-2021, 03:43 AM | #16 | |
This should answer the questions - https://www.cokertire.com/blog/tube-tech
WHEEL FLAPS - https://www.cokertire.com/accessorie...ers/flaps.html WHEEL RIM STRIPS - https://www.cokertire.com/accessorie...im-strips.html ADDENDUM (Fr. For More Info) - Quote:
SOURCE - https://www.hotrod.com/articles/moun...wire-wheels-2/
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 05-25-2021 at 07:49 AM. Reason: CRS - ADVANCED |
05-26-2021, 12:17 PM | #17 |
FWIW: In my very early autoX days I ran an MGB with wire wheels. They had a thick rubber band over the ends of the spokes. It fit pretty tight and I never had a problem with it.
I also ran radial tires (street and autoX) with tubes for years - again no problems.
1955 Customline 4dr, 292 2bbl, 3sp |
05-26-2021, 12:58 PM | #18 | ||
Steve McQueen II is also a tire expert ...
SOURCE - COKER TIRE
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
05-26-2021, 01:42 PM | #19 |
A note of caution when putting tubes in radial tires...
Because radial tire sidewalls flex more than bias-ply tires they generate more heat in the sidewall. That heat can cause sudden failure of a 'generic' inner tube. Tubes rated for radial tires are available. https://firestonetubes.com/policies-and-forms/page/1/tube-safety . Last edited by dmsfrr; 05-27-2021 at 10:27 AM. |
05-27-2021, 10:03 AM | #20 |
I have True Spoke wheels on my 55 Fairlane, had a valve stem break off from age. Took it to a local tire shop to have it fixed, this guy has bee in the tire business for years and knows his business. He told me to get a heavy duty tube a size smaller than tire, rim size, He said it would not try to wrinkle up when installing and he used talc powder so it would slip inside the tire when airing up. I'm using Coker wide whites, but haven't driven them that much. Tires and tubes were 11yrs. old so I put all new on 2 yrs. ago.
