07-13-2020, 03:24 PM | #1 |
1935 Distributor Upgrade
What parts are needed to upgrade a stock 1935 distributor to improve the advance curve?
I have not found a definitive list. I highlighted the parts that I think are needed: Thank you in advance-
Tim Downtown, Ca |
07-13-2020, 03:28 PM | #2 |
Re: 1935 Distributor Upgrade
07-13-2020, 10:21 PM | #3 |
You surmise correctly
07-14-2020, 12:24 AM | #4 |
If it´s a stock -35 engine it will not like the added advance...just my 2c.
07-14-2020, 02:03 AM | #5 |
Use the 68 advance
07-14-2020, 05:37 AM | #6 |
07-14-2020, 01:41 PM | #7 | |
The snap ring highlighted is the same either way. You can reuse the cast lower housing but you will need to remove the oil shield. While the 11A is a improvement, the BIGGEST plus is being able to run the 37-48 points and getting away from the junk early points. 68 series runs well too either way the points are the big improvement. |
