06-09-2020, 08:11 AM | #1 |
Thump thump thump
Wondering what the possibilities might be. At low speed 10-15 mph, with the clutch engaged I hear a thump thump thump coming from I think the rear of the car. It stops as soon as I put the clutch in. I feel no vibration at either slow or road speed. What would be the most logical cause? Thanks
06-09-2020, 09:30 AM | #2 |
Re: Thump thump thump
Check your private messages in the top right corner of this webpage.
Marshall |
06-09-2020, 09:51 AM | #3 |
Loose wheel???
Loose axle nut?? |
06-09-2020, 04:16 PM | #4 |
06-09-2020, 11:46 PM | #5 |
Chipped gear tooth?
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
06-10-2020, 07:25 AM | #6 |
Paul in CT |
06-11-2020, 06:27 PM | #7 |
I had a similar noise. It turned out to be a bad universal joint.
Ken
Style beats speed any day, and with a lot fewer tickets. |
06-13-2020, 02:44 PM | #8 |
Thanks everyone. No loose wheels or axle nuts. Will have a look at the inside of the rear end to see if anything is as it should be. It is kinda weird though, Say you are going about 10 - 15 mph just kinda idling along and you can hear the thump but the instant you push the clutch in, the noise stops. I would think a u joint would still make noise. Also there is zero vibration at any speed. Thanks again
06-15-2020, 09:59 AM | #9 |
Just guessing here. Have yo lubricated the clutch through the top inspection hole recently? Could the throwout bearing or TO bearing hub not be evenly seating? There is a spring on the TOB Hub that may be weak??? Might be able to see something through the bell housing inspection/oiling hole.
Again, just a guess... Keep us posted. Chap |
