Old 04-25-2020, 07:58 PM   #1
burner31
burner31's Avatar
Default changing brake cam support
Does the brake shaft have to be disconnected from the band and pulled completely out in order to change the brake cam support.
Same question for the clutch and reverse.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-25-2020, 09:17 PM   #2
redmodelt
redmodelt's Avatar
Default Re: changing brake cam support
You have to pull the hogs head to replace the low(clutch) cam. This part;
https://www.modeltford.com/item/3428.aspx it's riveted to the shaft which needs to be supported when the rivet is driven out. Also, the shafts go thru them so yes the pedals need to be removed. You might be able to get to the head of the bolt thru the door for the brake cam, but don't think you could for reverse. Don't loose the bolts, they are special thin headed ones.
