04-20-2020, 11:17 AM | #1 |
Cross Sectional cut of iron head thickness.
Looking for a photo and, or measurement of the thickness of a 8BA iron head across the dome portion of the combustion chamber. I'd rather not have to cut one if that info is available elsewhere. Perhaps from a Ford print?
Thank you |
04-20-2020, 03:24 PM | #2 |
Re: Cross Sectional cut of iron head thickness.
A quick sonic test would give you the thickness any good auto machine shop should be able to do that measurement.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
04-20-2020, 04:15 PM | #3 |
I have a cut through 8ba head on my wall,it came from our dragster, the cast thickness i will measure today,BUT is one of the nicest uniform castings I have seen, about 1/4 -5/16 thick.
Lawrie |
04-20-2020, 06:47 PM | #4 |
The thickness above the combustion chamber is ..250 in and the thickness on the top of the head is .187
This is an 8ba 8rt head Lawrie |
04-21-2020, 12:07 AM | #5 |
Lawrie, that is perfect! Wonder how much can be taken off the dome area before it blows up?
04-21-2020, 12:18 AM | #6 |
Lawrie |
04-21-2020, 08:32 AM | #7 |
I had flat piston 21 stud heads modified for dome top pistons. You can do it with cast iron heads but not aluminum.
04-21-2020, 10:12 AM | #8 | |
The engine I'm contemplating will have no boost. Do you suppose a stock iron head can survive with 1/16" less thickness over the piston? I'm thinking it will in a street motor. |
04-21-2020, 10:28 AM | #9 |
I'm sure it would be strong enough, but the temperature difference s between the thin and thicker portion of the combustion chamber would be prone to cracking.
04-21-2020, 09:44 PM | #10 |
Ron
Where would the cold spots be? |
04-22-2020, 09:23 AM | #11 |
I would assume near the water jackets. The head gets hot, the water cools. Especially under hi loading of the engine
