Old 02-19-2020, 06:02 PM   #1
burner31
burner31's Avatar
Default Oil pan hole, what is it?
Can someone tell me what the hole in the front of the pan is?
Our local history museum has a 1917 Model T that I am trying to get running and I seen this hole...what the hell is it? What hooks up to it (steering rod?)
It's at the front of the pan left side on the picture, can't miss it.
I'm volunteering my time and labor (working alone), I'm a model A man myself and know nothing about T's.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 02-19-2020, 06:29 PM   #2
gz
gz's Avatar
Default Re: Oil pan hole, what is it?
The hole allows access to the pin that holds the pulley onto the crankshaft. Without the hole, it would be really hard to remove and replace the pin.
Also, if your front seal leaks, this hole allows the oil to get onto your garage floor.
gz is offline   Reply With Quote
Old 02-19-2020, 10:48 PM   #3
redmodelt
redmodelt's Avatar
Old 02-20-2020, 01:16 AM   #4
burner31
burner31's Avatar
So I don't have to worry about it?
Keith
Shawnee OK
'31 SW 160-B
Old 02-20-2020, 01:32 AM   #5
redmodelt
redmodelt's Avatar
No you don't, it's factory
Old 02-20-2020, 09:20 AM   #6
burner31
burner31's Avatar
Thanks guys, this is a fun learning experience.
I'll be back on here many times as we work on this at the museum, today the wheels comes off for new ones, donated by Fred's tires in Shawnee, OK
I should seek out a Model T guy near Shawnee, I'll start a new thread.
Keith
Shawnee OK
'31 SW 160-B
Old 02-22-2020, 10:53 PM   #7
markwilltoo
You might also want to try the forum at www.mtfca.com.
markwilltoo is offline   Reply With Quote
