12-02-2019, 08:49 PM | #1 |
Low to High Gear
Wondering the cause of chatter from low to high gear it smooths out when fully engaged. Any thoughts?
12-02-2019, 09:25 PM | #2 |
Re: Low to High Gear
Maybe not letting the low pedal up smoothly or not backing off the throttle when you up shift.
12-02-2019, 10:54 PM | #3 |
I’ve noticed not everyone will back off the power when engaging high gear. You should. Also believe it or not I changed from generic to Valvoline oil and it made the the clutch smoother.
12-05-2019, 09:25 AM | #4 |
My 23 dose the same thing its really bad the hole front end shakes bad double clutch back off the throttle then it bogs and slowly picks up speed top out about 50 on my phone app not good emr brake high speed backs off about 5 clicks have to hold with foot will replace ratchet and paul today o what fun Santa at maricopasants.com
12-05-2019, 10:57 AM | #5 |
This is caused by either driver technique or a weak clutch spring, or both.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
12-05-2019, 10:09 PM | #6 |
12-08-2019, 07:51 PM | #7 |
Our '21 Touring did the same when I first started driving it.
No more...It either got "broke in" or I learned how to drive it. Just saying... |
