10-01-2019, 12:21 PM | #1 |
1929 Ford Model A trunk deck prop
Just purchased a new trunk deck prop for my model A 1929 Standard Coupe and when i tried to mount it on the deck i found that the two screw area is on an angle and throws the whole think off by about 30 degrees. The listing showed these the same for 28-31 What could be the issue? Anyone?
10-01-2019, 01:49 PM | #2 |
Re: 1929 Ford Model A trunk deck prop
This shows what you need and how to attach it.
http://www.plucks329s.org/pdf/studie...%20PART_1A.pdf Maybe it was put together wrong or is bent..They should fit though with no problem. Pluck |
10-01-2019, 02:49 PM | #3 |
i see more of an angle in the two originals. This repop is made with no angle on the plate where it screws to the deck lid.
10-01-2019, 03:29 PM | #4 |
I bought the same one for a 31 and had to modify it (bend) to fit.
10-01-2019, 11:26 PM | #5 |
