08-06-2018, 04:31 PM | #1 |
Ammeter "-", generator motors...hep
OK...yesterday we went for a drive and afterwards at home I noticed the ammeter in the negative with everything turned off so I disconnected the battery. Today I loosened the generator belt, reattached the battery, and the generator slowly turned. (Again, everything was off.) I am assuming the cut-out is bad. Does filing the cut-out points work or is a new one the only real solution???
"I have not yet begun to defile myself." -Doc Holliday '31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex Last edited by braol; 08-06-2018 at 04:41 PM. |
08-06-2018, 07:38 PM | #2 |
Re: Ammeter "-", generator motors...hep
Repair the old one or get a fun projects voltage regulator to replace it. New repro cutouts are trouble I hear.
08-06-2018, 08:41 PM | #3 |
Clean the points up and give it a try. The return spring may also be weak. Volt reg. is a good upgrade, as well as the diode kit, but if your cutout is original Ford give it to someone that might want to rebuild it, don't toss it in the trash.
08-06-2018, 10:23 PM | #4 |
If the old is a reproduction then replace it with a solid state cutout (diode) if original open it up and inspect the ground wire as it often works its self loose.
08-07-2018, 11:40 AM | #5 |
Great forum Thanks for all the help!!!!
"I have not yet begun to defile myself." -Doc Holliday '31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex |
