07-06-2018, 12:30 PM | #1 |
(Advice/tips)Leaking gas from rivets surrounding shutoff valve
Well looking for tips and advice on how to go about fixing small leak from the rivets that surround the shutoff valve. We were dealing with a leaky valve before (now fixed) and now it seems that the tank itself has tiny cracks allowing a small amount of gas out through the 3 rivets. Thanks again!
07-06-2018, 12:54 PM | #2 | |
Re: (Advice/tips)Leaking gas from rivets surrounding shutoff valve
07-06-2018, 02:03 PM | #3 |
The real fix is to remove tank and properly fix,not good! Ditto F.M.!
www.whidbeymodelaclub.com |
07-06-2018, 02:18 PM | #4 |
Remove the tank and have a professional repair it. You may not like the bottom line but it's better than a fire.
07-06-2018, 02:57 PM | #5 |
Step one please remove the rubber hose!!
I had the same problem with my tank. I cleaned the area and cleaned the area again. Then I applied JBweld for gas,been leak free for 2 years. I do check it regularly if the leak returns I will remove the tank and have it Professionally repaired !! You never should have gas leaking.
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
07-06-2018, 03:08 PM | #6 |
07-06-2018, 03:17 PM | #7 |
the hose is there to drain the tank
07-06-2018, 03:24 PM | #8 |
Agreed, we are getting it repaired; no epoxy or JB weld for this one. We have the body off and want it done right before we re-assemble. 29 Tudor matching numbers with 1973 Title out of Michigan. Not repainting it; long block engine rebuild by Rich at Antique Engine in Skokie, Ill.
07-06-2018, 03:39 PM | #9 |
Sounds like a smart decision to me.
07-06-2018, 06:51 PM | #10 | |
So I did the JB weld trick. I didn’t want to remove the tank and ruin a new paint job!
07-06-2018, 07:36 PM | #11 |
I would have done the same thing if it was going to mess up the paint.
07-09-2018, 06:06 PM | #12 |
07-09-2018, 06:46 PM | #13 |
What would be a proper repair for this problem? Remove the tank and replace the damaged metal? How did they buck those rivets when the cars were new, special bucking bar? Seems like it would be a fun project. Mike
07-09-2018, 06:59 PM | #14 |
I believe the items riveted to the gas tank (steering column bracket, choke bracket and shutoff threaded insert) were installed (riveted) before the tank was electro-welded up. Before welding the heads of the rivets were accessible for bucking.
Rusty Nelson |
07-09-2018, 07:30 PM | #15 |
Thanks for your answer wrndln. So could an "access" be cut out of the firewall side so as to "tighten" the leaking rivets with a rivet gun? My Coupe always "sweat" fuel from the rivets for the steering column bracket and I never fixed it properly, just smeared a little bar soap on the area and went on for another 6 months. Mike
07-10-2018, 08:20 AM | #16 | |
07-14-2018, 11:11 AM | #17 | |
I don't understand the rivets, but then again, I don't understand the rubber hose. The only real solution is getting the tank removed and taking it to someone who can fix the problem or direct you to a good repaired available gas tank. There are plenty of posts on tank removal based on the year of your Model A. You will be much better off, fixing this right, AND GETTING RID OF THE RUBBER HOSE! And having a safe car to drive!!!!! |
07-15-2018, 08:15 AM | #18 | |
07-18-2018, 11:34 AM | #19 |
07-19-2018, 04:18 PM | #20 |
Katy
If you have any alcohol in the gasoline, that will soften the J B Weld. Straight gas won't affect it. Jim |
