03-11-2018, 09:52 AM | #1 |
Removing caked on grease and crud
I typically beadblast most of the parts in am restoring. However, it is very hard to blast off grease and grease laden crud. Usually the grease is also covered with dirt and other crud. I can scrape off some of the crud with a putty knife, but grease is hard to remove and beadblasting grease takes forever to remove. I would like a chemical that is easy to dispose of, not a solvent based liquid. I know petroleum based degreasers work well, but hard to dispose of when the part(s) are degreased. If someone has found a good, cheap degreaser that I can pour in a pan to submerge the part in to remove most or all the crud before beadblasting, would you post it below?
Rusty Nelson |
03-11-2018, 09:58 AM | #2 |
Re: Removing caked on grease and crud
When I cleaned up my early 1929 Tudor parts, I used Simple Green. It not only left the original paint but did a good job on losening up the hard grease and grime.
However...if the part is left in the Simple Green to long...it will also work on the old paint also. 24 hours was best for me. Pluck |
03-11-2018, 10:03 AM | #3 |
Thanks, Steve for the tip.
Rusty Nelson |
03-11-2018, 10:39 AM | #4 |
A pressure washer with a recovery area works best. A plastic tarp and a kiddie pool make the recovery area. Then the cleaner of choice. I use mineral spirits. Never had much luck with non-petroleum solutions.
03-11-2018, 10:56 AM | #5 |
Soak in diesel.
03-11-2018, 11:03 AM | #6 |
03-11-2018, 11:06 AM | #7 |
On parts and pieces that can handle heat use a torch to heat the grease until it burns out the oils. Will blast clean easily then.
Dave / Lincoln Nebraska |
03-11-2018, 11:15 AM | #8 |
Scrape as best you can
Oven cleaner in the sun Hot water/pressure wash |
03-11-2018, 12:25 PM | #9 | |
Bill Tired
03-11-2018, 01:10 PM | #10 |
i soaked parts on kerosene for long periods and it turned the caked grease back into grease. Usually a stiff brush i could brush it off or putty knife scraped it off much easier.
1929 Model AA - Need long splash aprons! |
03-11-2018, 04:43 PM | #11 |
If the parts are small enough, I submerge them in a drum of caustic soda and connect the battery charger to it and an electrode also hanging in the caustic. I vary the current by increasing/decreasing the amount of electrode in the caustic so I use all the charger can put out without going off the scale. Sometimes, it is just a piece of sheetmetal offcut, sometimes a piece of rod so it works for the whole length of the component.
Parts come out with out paint.
03-11-2018, 05:39 PM | #12 | |
Scrape off most of the crud with a putty knife before using the oven cleaner. Might take a second application to get really thick crud off.
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
03-11-2018, 07:01 PM | #13 |
Yep, oven cleaner, scrape the thick stuff and spray, may require several apps.
03-11-2018, 07:16 PM | #14 |
Thanks all for the degreasing tips. Looks like oven cleaner and maybe electrolysis is worth a try.
Rusty Nelson |
03-12-2018, 01:38 AM | #15 | |
If using oven cleaner, make sure to wear a mask ! It will only take a small wiff of that stuff in your nose to show why a mask is necessary. It cuts grease well though. If you are concerned regarding environment and disposal, remember; 'a drop of DAWN and the grease is gone' ! Liquid dish soap that is. Last edited by hardtimes; 03-12-2018 at 12:39 PM. Reason: ................ |
03-12-2018, 06:13 PM | #16 |
The oven cleaner will do the trick. But be mindful when you are brushing it ,to wear a long sleeve shirt and gloves and most importantly good eye protection. That stuff will burn like hades. And forget it if you get into your eyes. Cleaning the parts is great. but not at the expense of your eyesight. And the mask as hardtimes suggested is mandatory also.
old car guy |
03-12-2018, 06:37 PM | #17 |
Check You tube for electrolysis methods and results.
I like Super Purple. Auto Zone has it on sale quite often. |
03-12-2018, 06:57 PM | #18 |
Rusty, if you want to use something that is safe and doesn’t screw everything up, use Dawn dishwashing liquid soap. It doesn’t even bother my hands although I do use a hand moisturizer and my hands aren’t all cracked and dry.
I mix it 50/50 with water and let stuff soak overnight, and it softens just about anything. You are still going to have toxic crud leftover, but it’s better than solvent or other hazardous stuff. If it removes grease and oil from those poor Exxon ducks, it will soften that grease and crud of yours so it’s easy to wipe or brush off. Mike |
03-12-2018, 07:14 PM | #19 |
Scrape off the excess with a chisel. Then, using good rubber gloves, apply some methylene chloride (paint remover.) Let set, then scrape again with a chisel and some coarse steel wool. Wipe clean with Mineral Spirits to remove residual oils. Gets you down to sanding prior to priming and paint.
Good enough.. Isn't. |
03-12-2018, 08:48 PM | #20 |
X2 on super purple. If you haven't used it before, you will be amazed at how it cuts thru 90 years of muck.
