Old 02-28-2018, 06:26 PM   #1
Brian SATX
Brian SATX's Avatar
Default 30-31 radiator shell lacing rivets
Does anyone have a picture of an original 30-31 shell lacing showing the rivets from the inside? Are they flat or a slight curve to them?
Brian SATX
Brian SATX is offline   Reply With Quote
Old 02-28-2018, 06:33 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: 30-31 radiator shell lacing rivets
the back of the rivets always had a slight curve to them.
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 03-01-2018, 06:38 AM   #3
Ed Saniewski
Ed Saniewski's Avatar
Model T guy's have a tool that comes pretty close to the correct shape.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 03-02-2018, 01:33 PM   #4
burner31
burner31's Avatar
MSMARON is correct
Changed mine out (original mostly gone)
Sorry...no pics
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 03-02-2018, 02:04 PM   #5
msmaron
msmaron's Avatar
This might help you also...
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 03-02-2018, 04:45 PM   #6
kimeccles
kimeccles's Avatar
to do them right with the curve you need the special split rivet pliers
https://www.macsautoparts.com/ford_m...-set-tool.html
I will sell you mine (used once) for $25 including shipping. These are clunky, Chinese made, but after a couple tries and learning the technique of putting them in and spreading them a tiny bit apart first I got real nice results with the curves for the cowl.
PM me if interested
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 03-02-2018, 09:55 PM   #7
Brian SATX
Brian SATX's Avatar
Thanks to all. ModelACoupe3 sent me pics of his original.
Thanks for the offer on the tool, if only it had come a few days earlier.
Brian SATX
Old 03-03-2018, 03:32 PM   #8
BillCNC
BillCNC's Avatar
I thought about buying the tool from the vendors but thought it was to pricey for what it is.Instead, I made a tool from a pair of Harbor Fright vise grip pliers and used a Dremel cutoff wheel, a couple of files and about 15 minutes of time. Work's like a champ!
I also used it on the Cowl lacing clips on the ends.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-04-2018, 08:49 AM   #9
1930marie
1930marie's Avatar
Thank you for excellent photos posting! I will have at making mine today.
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 03-04-2018, 10:34 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Marco made a nice rivet setting tool out of a pliers, and he posted pictures of it here some years ago. Maybe a search will find those pictures. I'll try, but I don't always luck out in my searches.
Old 03-04-2018, 03:01 PM   #11
BillCNC
BillCNC's Avatar
The nice thing about the vise grips is you can set the depth of the tool to go only to the bottom of the "V" and you can adjust the tension of the grip. Basically you give it some force to the point of bending the rivet ttangs and the spring in the vise grips does the rest.
The slight radius on the bottom sides of the "^" point of the tool creates the final position of the rivet tangs and starts the bend. To little and it's hard to get the bend started, to much will cause the rivet tangs standing up to tall. It takes a rivet or two to get it working perfectly. Just follow up on the first couple rivets after you have it dialed in.
It sounds more complicated than it really is.
The only thing I would change is possibly adding some felt on the other side of the tool protecting the finish on the rivet head. I used a rag so it would save the extra step in doing so.
Regards
Bill
Old 03-04-2018, 11:53 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Regards
Bill
How about filing the top teeth off and making it smooth or after making it smooth, use the dremel to create a little concave area for the head?
Old 03-05-2018, 06:00 AM   #13
1930marie
1930marie's Avatar
Thanks Tom -
Old 03-05-2018, 06:07 AM   #14
1930marie
1930marie's Avatar
Regards
Bill
Bill thanks again for your posting. I had at it yesterday and it works great! I filed the teeth off on the otherside and put a small piece of gorilla tape on it. I really enjoyed the success feeling of making the tool as much as how good my shell cowling looks. Thanks!
Old 03-16-2018, 03:14 PM   #15
BillCNC
BillCNC's Avatar
Your welcome.
One of the easiest tools to make and everyone has an old and tired pair of vise grips to spare.
Regards
Bill
Sent from my SM-G920T using Tapatalk
