12-16-2010, 12:09 PM | #1 |
Spoon Gas Pedal disassembly??
Can the pin be removed to take apart a spoon gas pedal? I gave one a couple of tries (from both ends) with a pin punch and it doesn't seem to want to budge. Maybe a little bit of heat? Thanks!!
12-16-2010, 12:27 PM | #2 |
Re: Spoon Gas Pedal disassembly??
pete, i`ve taken apart several spoon pedals. some of them come apart with a few vigorous thumps with a pin punch and hammer. and i`ve had a few that i had to use heat and get VERY aggressive with.
12-16-2010, 12:30 PM | #3 | |
A little heat works good. A lot works better. The pin will come out. Here are a couple of pictures of my build. Had to shorten the shaft to fit the Model A firewall. The aluminum template is for drilling the hole in the firewall for the throttle arm. The arm had to be heated and re-shaped to work properly.
If it's too loud, you're too old. Last edited by av8paul; 12-16-2010 at 12:42 PM. |
12-16-2010, 12:45 PM | #4 |
And if you need extra material or arms, I believe all the many variants of '32-48 gas pedal cross shafts use the same diameter stock and can be grafted right into an early spoon.
12-16-2010, 04:54 PM | #5 |
Thanks. Think I know what I'll be doing tomorrow.
PS: Paul- You didn't try to get the "twisty" shaft outside the fire wall?
12-16-2010, 09:21 PM | #6 | |
Not enough room. The engine's so close to the firewall, I can't even run the mechanical fuel pump.
If it's too loud, you're too old. |
