Old 10-05-2017, 08:02 PM   #1
gary678*
Default "B" cylinder heads
I am new to the hobby. Any comments or thoughts on the "B" cylinder head 5.22 compression ratio) ?
gary678* is offline   Reply With Quote
Old 10-05-2017, 08:06 PM   #2
tinkirk
tinkirk's Avatar
Default Re: "B" cylinder heads
If you have the coin to spend go with at least the 6.0 or higher
You won't be sorry
tinkirk is offline   Reply With Quote
Old 10-05-2017, 08:13 PM   #3
Beater
Beater's Avatar
I thought when you get the comp up that high it will pound out there bearings in short order?
Beater is offline   Reply With Quote
Old 10-05-2017, 09:58 PM   #4
ursus
The Ford Model-B head ( with a cast-in "C") made for 1932-34 engines has compression ratio that is only slightly higher than a Model-A, at 4.6 to 1. The high compression "B" head sold during the Model A era was 5.22 to 1.
ursus is offline   Reply With Quote
Old 10-06-2017, 12:00 AM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
It’s a c head for a b motor. A b head is for an a motor. The progression of letters is the order of part changes. You can fit either head on either motor, but the water pumps are a different bolt pattern.
Old 10-06-2017, 04:43 AM   #6
tinkirk
tinkirk's Avatar
If you pay attention to your timing you will have no problems
People have run higher than 6, 7,
With no issues
Pick up one of Jim Brielies books lots of info in there
Old 10-06-2017, 07:57 AM   #7
gary678*
THANKS FOR THE COMMENTS! Gary D.
Old 10-06-2017, 10:27 AM   #8
jim1932
jim1932's Avatar
for clarification this is the model A police head with the B.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 10-06-2017, 10:37 AM   #9
glenn in camino
glenn in camino's Avatar
I have a B 5.22 head on my late 31 sport coupe and one with the B ground off on my early 28 tudor. they both use stock 4 bolt water pumps. The C heads needs a 3 bolt pump.
glenn in camino is offline   Reply With Quote
Old 10-07-2017, 05:30 AM   #10
bnchief
bnchief's Avatar
Glenn I have a b head on my 30 tudor and they ground the b off of it as well do not know why judging perhaps?
bnchief is offline   Reply With Quote
Old 10-07-2017, 10:59 AM   #11
Jim Brierley
There seems to be a lot of concern about high compression doing damage to babbitt, this is definitely not true! It is detonation that will damage babbitt. With higher compression you may need to use less spark advance, everything else being equal, there will be no problem.
Jim Brierley is offline   Reply With Quote
