06-05-2017, 05:20 PM | #1 |
Dwell Meter Kal-Equip T-111 manual
I just purchased a Kal-Equip T-111 dwell meter.
Does anyone have a manual that they could scan or take pictures of? |
06-05-2017, 05:56 PM | #2 |
Re: Dwell Meter Kal-Equip T-111 manual
You might try the Garage journal under 'vintage tools'
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
06-05-2017, 05:59 PM | #3 |
That model was also marketed by NAPA
06-05-2017, 06:10 PM | #4 |
Got mine in mid 60's I think for GM cars. I do not have any papers for it.
06-05-2017, 06:29 PM | #5 |
I think those things are self explanatory.
06-05-2017, 07:03 PM | #6 |
I agree and they all seem to work the same. Set it for battery voltage and number of cylinders and whether you want dwell or tachometer, one clip on the hot side of the coil and one clip to ground. Why not search on You-tube for a demonstration? |
06-05-2017, 09:22 PM | #7 |
If you can work a wall light switch, you CAN work thet thing---LOL
Bill Simple
06-05-2017, 10:51 PM | #8 | |
[QUOTE=ursus;1482051]
Since you have a positive ground car, you may have to swap the two clips from what most negative ground cars are connected. |
06-05-2017, 11:13 PM | #9 |
This should be on the back. And if I remember correctly for 4 cylinders, double the 8 cyl readings.
06-06-2017, 09:22 AM | #10 |
Tuned a car, had it running with that same meter. Disconnected it & car DIED!
NEW Century brand condenser was defective. APPARENTLY, a condenser in the meter was serving the ignition system. Bill Baffled
06-07-2017, 04:43 AM | #11 |
Looks similar to mine
https://automotiveamerican.com/tag/dwell-meter/ Pretty straightforward, mine also has a buzz bar for current testing
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
06-07-2017, 07:57 AM | #12 |
I have a couple of these Kal-Equip meters, two are Tachometers, and the other two are Dwell meters.
All are in good cosmetic condition, but only the Tachometers function. Does anyone have these Kal-Equip Dwell meters that still work, or are mine just "special" ? Thanks ! |
06-07-2017, 02:11 PM | #13 |
06-07-2017, 02:12 PM | #14 |
06-07-2017, 06:43 PM | #15 |
I have an old Fox Valley tack, dwell, volt and amps that still works. Have had to modify for the battery and the leads are getting frayed. Had it 50 years.
06-08-2017, 08:23 AM | #16 |
06-08-2017, 08:25 AM | #17 |
