04-06-2017, 09:45 AM | #1 |
HELP: ready to start again...n/g
Hi Guys, I took my car apart 5 months ago...It was running fine. Now I put it all back together and it won't start. I sanded the points, checked the spark at the points(nice blue), took the plugs out cleaned them(they were wet. Checked the gap (35). Charged the battery fully (twice), filled the cells with distilled water. I had installed new tail lights , head lights, they are all working fine and the horn is also.
I put 2 tablespoons of MMO in each cylinder and turned it by hand 10 times, replaced the plugs and zippo, no start. I took the plugs out again and they were soaked again??? What have i missed? Frustrated in Florida. Thanks. |
04-06-2017, 09:54 AM | #2 | ||
Re: HELP: ready to start again...n/g
04-06-2017, 10:01 AM | #3 |
Sounds like you have gas and spark. Air is a given.
Take the distributor cap off. When you crank the car, does the rotor spin? I've had the oil pump gear break after a car sat for a while and while all conditions seemed perfect, The distributor rotor wasn't spinning. This is down at the bottom of the distributor shaft and has a pin in it that can sheer.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
04-06-2017, 10:09 AM | #4 |
They are soaked with gas...
I'm quickly becoming a "Specialist" in which I know more and more about less and less until I know everything about Nothing! |
04-06-2017, 10:11 AM | #5 |
thanks didn't check that but i will now...
04-06-2017, 10:15 AM | #6 |
Sewall |
04-06-2017, 10:17 AM | #7 |
Tap on the carb, "maybe" the float valve is stuck open???---ALSO, hold the throttle WIDE OPEN while cranking, to UN-FLOOD it.
Bill W.
04-06-2017, 10:28 AM | #8 |
Yes will come from carb throat if i hold it too long. OK will try the tapping too.
04-06-2017, 10:49 AM | #9 |
Two tablespoons of MMO in each cylinder seems like a lot. Is that what is fouling the plugs?
04-06-2017, 10:57 AM | #10 |
Gee Art i meant teaspoons...just a dash. I though maybe upper cylinders would be deplete of oil after 5 months?
04-06-2017, 10:58 AM | #11 |
Yes the rotor turns completely around..
04-06-2017, 11:03 AM | #12 |
Katy...the spark IS small with a cracking sound. I'm wondering if the distributor body has a bad ground to block from sitting (could that be possible?) Tapping the carb didn't help it start ...it turns over but no hint of any firing going on .
04-06-2017, 11:04 AM | #13 |
Did you put fresh gas into the tank? This new gas goes bad in a couple of months.
Charlie Stephens |
04-06-2017, 11:06 AM | #14 |
Hi Candle,
Florida humidity vs. dry air in Arizona in either the Fall or Spring with cool nights and warm humid days ...... very possible condensate moisture/water mixed in with regular gas or ethanol gas when purchased, or when stored a few months in gas tank, in sediment bowl, and/or in carburetor bowl. If everything electrical works, and one gets good spark at plugs when engine cranks, and engine is getting fuel and not flooding, try completely draining gas tank, sediment bowl, & carburetor and replenish with "fresh" gas. |
04-06-2017, 11:09 AM | #15 |
Charlie: no i used some from the shed for the lawn mower...Only put about a pint in... I'll go get some new gas...I also use Seafoam in my gas. I didn't realize that it goes bad...thanks.
04-06-2017, 11:11 AM | #16 |
H.L. yes that's what i'm going to do next...fresh gas..sigh...lol the gas was not in teh tank for 5 months...I had a hole in the tank and i took the tank out 5 months ago to have it fixed. But i will drain what i did put in and go get some new.
04-06-2017, 11:15 AM | #17 |
Yeah. If you painted the engine and the distributor body is not getting a good ground to the block, your spark plugs may not be doing the work they need to do.
04-06-2017, 11:17 AM | #18 |
ok Jason will check that too... I'm sure this will be resolved by the end of the day...hahaha
04-06-2017, 11:25 AM | #19 |
If you don't have a hot blue spark at least 1/4" long, then you need to fix that before you do anything else.
04-06-2017, 12:14 PM | #20 |
Florida ... humidity ..... Springtime or Fall ..... cool nights ...... warm moist days .... unconditioned garage ...... warm moist air condensing on many different cool metal electrical connections causing metal oxidation on metal wire connections retarding electrical flow ..... can happen occasionally in only five (5) months when Model A is not in use ...... multi-meter electrical check from battery to plugs never a bad idea in addition to moisture in fuel.
From years of experience: Used on wire connections located on half mile high coastal communications towers .... expensive because of large 8 oz. container, (used to have 4 oz.); but, will protect and end all Model A "exposed" electrical connection problems for almost eternity. Kopr-Shield TM Compound-The copper colloidal surface treatment that protects, lubricates and enhances conductivity between all electrical connections. Catalog No: CP8-TB, Codale Item No: 8777, UPC: 78621080636T&B CP8TB 8OZ CORROSION INHIBITOR Kopr-Shield Price: $18.98 ea |
