Old 07-31-2016, 12:00 PM   #1
1956 F100
1956 F100's Avatar
Default !934 Window Channels
I have a window kit from Vintique for my 34 sedan. I need to cut the channel to work on my car. Would anyone have a set of original that they could take dimensions off of? It looks like they need to be cut on both ends. I am currently working on installing the rear windows. Any help is greatly appreciated. Gary
1956 F100 is offline   Reply With Quote
Old 07-31-2016, 01:42 PM   #2
johnboy34
Default Re: !934 Window Channels
I put some links on your other thread. I can offer that if you have glass, have someone hold it in place then hold up the channel for measurement. Shorten it just enough to not hit the end channels ( after sliding back also ). Then put it on the glass ( mocked up in the car, with the regulator installed also ) Mark where it will need to be on the glass, remove and install channel to glass. I know, not much room, and the slide back lower post and stop screw hole of Vintique channels are off too. Makes it a bitch, That's where the other links come in handy. Make sure that part ( regulator and channel ) work together on the bench first. Hope some of this helps, good luck, you will get it.
johnboy34 is offline   Reply With Quote
