Old 06-14-2016, 09:15 PM   #1
bogdonj
bogdonj's Avatar
Default Transmission Question
Hey Guys!
Quick question regarding the transmission main shaft. I'm currently rebuilding my Roadster transmission and have come across a problem I have never experienced. All the gears in the tranny are good. Basically replacing all bearings and had to replaced the main drive gear because of wear and pitting. The Main Shaft looks good but here is the questions. The U joint bolt and washer that goes into the shaft seems to only tighten half way.. I ordered a new bolt and it stops half way also. Wondering if it's stripped????? Should I..
A. Chase the thread and tap it?
B. Order a new main shaft?
any help would be great.
Justin
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 06-14-2016, 10:11 PM   #2
RonC
RonC's Avatar
Default Re: Transmission Question
Is there dirt in the bolt hole? Try spraying brake clean or carb cleaner to rinse out hole. When you disasembled the ujoint from the shaft was the bolt seated?
RonC is offline   Reply With Quote
Old 06-14-2016, 10:37 PM   #3
bogdonj
bogdonj's Avatar
Thanks Ron, I will try that first. I noticed it wasn't seated when disassembling it. Thought maybe the last person just didn't tighten it down enough.
Old 06-14-2016, 10:54 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
3/8-24 x 1, do you have these dimensions?
Old 06-15-2016, 08:18 AM   #5
bogdonj
bogdonj's Avatar
after cleaning it and inspecting it looks like the threads half way down are stripped. I have a 3/8-24 tap that I will chase and try to fix it. Thanks Tom for the dimensions.
Old 06-15-2016, 12:22 PM   #6
bogdonj
bogdonj's Avatar
Used the correct tap thanks to Tom Wesenberg and it worked! Thanks!
Old 06-15-2016, 01:06 PM   #7
C26Pinelake
Tom is a walking, talking Model A book of knowledge! What would we ever do without him? Wayne
C26Pinelake is offline   Reply With Quote
