Old 03-04-2016, 09:54 PM   #1
Skeezixx
Skeezixx's Avatar
Default aoogah horn connections
Does it matter which side the wires go on when connecting the horn from the wiring harness?
It's a new Sparton horn from Bratton's if that makes any difference. The instructions just say "Plug in the wires."
Skeezixx is offline   Reply With Quote
Old 03-04-2016, 10:10 PM   #2
KansasRick
Default Re: aoogah horn connections
No difference......
KansasRick is offline   Reply With Quote
Old 03-04-2016, 10:34 PM   #3
Skeezixx
Skeezixx's Avatar
Thanks Rick.
Old 03-05-2016, 12:12 AM   #4
1930marie
1930marie's Avatar
FWIW: the horn is always hot, the button on the steering wheel completes the circuit. Positive ground is a natural ground not negative. Run a positivecground wire to your frame, body and transmission. Draw a circuit diagrahm to see whats going on with out these grounds.
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 03-05-2016, 07:15 AM   #5
Mitch//pa
Read post #17 from MikeK on the correct way to install the horn wire connections. Many make the mistake on installing the pigtail ends incorrectly.
https://fordbarn.com/forum/showthread...highlight=Horn
Old 03-05-2016, 02:20 PM   #6
Skeezixx
Skeezixx's Avatar
Mine installed from the bottom but I had to file the bullet ends a bit as they were oversized (as per Bratton's instructions).
Works fine every time.
Thanks Guys
