11-27-2015, 10:45 PM | #1 |
random radiator leak mystery to me
Happy Holidays Barners!!!
New radiator from brassworks is 3 years old......I have barely 1,000 miles on it since I do not get to drive my "A" as often as I'ld like. With the start of the cold season we have had nights in the 40s but nothing major and the car is in a covered garage. This morning as I check the engine over before an early morning drive I noticed a small puddle right under the front end. The radiator seems to have developed a leak...........DRIP....8 seconds.........DRIP.................8 seconds.........DRIP......so I start the car and proceed on my drive stopping every few blocks to get out and see if the leak continues.....NOTHING........... I get back from my drive of 20 miles......parked in the driveway, NOTHING. Pull into the garage, re-check the engine pull the safety fuse, and place a small plastic pan under the front end just in case......nothing. 10 hours later I go back and check the pan and the puddle is back. But the drips have almost 5 minutes in between....... Could this be from the cold having some weird effect on my radiator ? could it have developed a crack or leaky solder joint ? is it sweating ? Did something get loose somewhere I can't find since by this time I have inspected every inch of the top tank, sides, tubes and fins without physically removing the radiator ?? Any of you guys have this type if intermittent leaks with a newer radiator ?
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
11-27-2015, 10:52 PM | #2 |
Re: random radiator leak mystery to me
Check the hose clamps, especially the lower.
11-28-2015, 12:48 AM | #3 |
I had a cast iron water outlet that wouldn't quit dripping until I smoothed out the mold line with my Dremel. Two years ago my bottom water pipe developed a pin hole leak while I was on a 120 mile day trip. I had to tape it up to get home.
11-28-2015, 09:55 AM | #4 |
problem solved.....loose hose clamp and I thought I had checked everything in detail the first time, thanks for the reminders to be more thorough!
11-28-2015, 10:19 AM | #5 |
Even with Aeroseal hose clamps & new hoses, ever once in awhile Minerva would drip @ a hose connection. A re-tightening & she was good, until the next time?????
Bill W.
11-28-2015, 05:08 PM | #6 |
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
