Old 11-02-2015, 02:49 PM   #1
Modelacoupe3
Modelacoupe3's Avatar
Default Crankshaft machinist recommendations
Looking for a reputable machinist who can evaluate and properly machine the crankshaft from my 53,000 original mile Model A engine. Most important, I'm looking for someone who will keep the centerline within Ford Specs and maintain the correct radius. All journals are currently standard. One rod journal has slight damage from a bearing failure.
If possible, I would like to find someone near me (Torrance, California). If necessary, I will drive or ship the crank.
Thank you,
Scott
Modelacoupe3 is offline   Reply With Quote
Old 11-02-2015, 04:32 PM   #2
Kohnke Rebabbitting
Default Re: Crankshaft machinist recommendations
Thank you,
Scott
My machinest, Vern at Arnold Motor in Fort Doge, Iowa.
If you want it better then Fords.
800-765-2926
If you can find something wrong with it, I will pay for the job, and shipping.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 11-03-2015, 11:03 AM   #3
Modelacoupe3
Thank you Herm, I will give them a call. BTW, that's quite an endorsement.
Scott
Old 11-03-2015, 02:37 PM   #4
just plain bill
just plain bill's Avatar
I use castillo's in La Mirada 714 523 0321 Talk to Joe if you can. There is also a shop in Escondido that does babbit and could probably hook you up with who ever does their grinding.
just plain bill is offline   Reply With Quote
Old 11-03-2015, 02:50 PM   #5
Chris in CT
I know you want someone on the West Coast, but if you have trouble finding him, John or Mike at J&M Machine in Southboro, MA can help you out. Good Luck!
Chris in CT is offline   Reply With Quote
Old 11-03-2015, 03:10 PM   #6
darrylkmc
darrylkmc's Avatar
Thank you,
Scott
Are said Specifications readily available, or where can a fellow obtain them.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 11-04-2015, 01:54 AM   #7
diomed
diomed's Avatar
I second Castillo. Never heard anything bad from them.
Sent from my A0001 using Tapatalk
kris
diomed is offline   Reply With Quote
