10-29-2015, 08:45 AM | #1 |
Banjo Wheel Restoration Who Does It
I have come up with a fairly nice Banjo Steering wheel, but the rim
needs to be restored.... Can any of you recommend someone you know that does this kind of work ??? Any and All Leads or Help will be much appreciated Thanks....Les in Minnesota You can email directly if you like...sometimes it saves a bit of time |
10-29-2015, 11:57 AM | #2 |
Re: Banjo Wheel Restoration Who Does It
DO IT YOURSELF. It is not all that difficult. Look in the archives for postings on that subject. By all means, use PC7 as the repair medium. I have done a couple of them myself, and they turned out great.
10-30-2015, 10:50 AM | #3 |
Eastwood has a nice Kit with instructions.
10-30-2015, 11:30 AM | #4 |
I started with a badly cracked wheel and used PC7. It's not a hard job, enlarge the cracks, apply the mixture and a lot of shaping and sanding as I recall.
Before After |
10-30-2015, 04:42 PM | #5 |
Nice job. Good on you.
10-30-2015, 04:59 PM | #6 |
10-30-2015, 08:06 PM | #7 |
You can find PC7 at Ace Hardware, saw some on display last week.
10-31-2015, 08:53 AM | #8 |
When filling cracks with PC7 I use an air tool with a thin cut off wheel.
Cut down to the 3/8" steel ring, make it about 3/16" wide and drill 1/8" holes in both sides of the slots. Work the PC7 into the holes with a small screw driver. Over fill the slot slightly, wet your finger and smooth the joint leaving it slightly humped in the center. Sand smooth and prime with a good 2 part primer. G.M.
www.fordcollector.com |
10-31-2015, 09:07 AM | #9 |
I started one using JB Weld. Should I take this out and start over with PC7?
10-31-2015, 10:47 AM | #10 |
PC7 is a "putty like" epoxy resin mix and is easier to work than a more liquid like epoxy resin. If you had good results with the JB weld then put a leever on it and leever alone.
10-31-2015, 04:04 PM | #11 | |
on the first wheel I did but found it to runny. The PC7 I believe bonds good and may be a little flexible so it don't crack. I have never had a problem with PC7 and I always drill 1/8" holes any place used to key it together. G.M.
10-31-2015, 08:14 PM | #12 |
I used the kit from Eastwoods for my '34 pickup and the PC-7 worked great!! The "book/instruction" manual was very helpful and worth purchasing from Eastwoods as well.
11-02-2015, 11:49 AM | #13 |
I used JB Weld. I felt the 'runny' part was a plus; it enables the epoxy to seep deeper into the cracks. I also feel JB is easier to work with. I than used a 'fine' file to shape it before sanding and priming. The wheel looks AWESOME!
11-02-2015, 01:58 PM | #14 |
I used JB weld and it turned out fine. It is for sale.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
