Old 07-20-2015, 06:14 PM   #1
james hitchcock
james hitchcock's Avatar
Default Trying to remove speedo gear case.
Quick question. Do I have to drop my brake cross shaft in order to remove the speedo gear case ? Cross shaft is right up almost against the gear case. Should it be so close ? Wondering if my rear motor mounts have let things drop a bit ?
james hitchcock is offline   Reply With Quote
Old 07-20-2015, 06:31 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Trying to remove speedo gear case.
James, a jack under the transmission "might" help, let us know.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-20-2015, 06:46 PM   #3
james hitchcock
Bill, I started to jack it up and stopped, thought I'd ask first.
Old 07-20-2015, 08:42 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
It does sound like you have frame sag. I removed my speedometer case without removing anything else.
Old 07-20-2015, 09:26 PM   #5
james hitchcock
Yikes.
Old 07-20-2015, 09:44 PM   #6
Mitch//pa
if your service brake cross shaft is not adjusted properly (the outer levers should be vertical) that can cause it to be to close to the speedo turtle....
with the levers vertical the cross shaft should be slightly behind the turtle allowing for easy removal
Old 07-20-2015, 09:45 PM   #7
1955cj5
1955cj5's Avatar
Mine was really close...I was just able to get the bolts out and the turtle slipped out....the tricky part was getting it back in with the gasket intact and in the right place
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
