06-16-2015, 11:27 AM | #1 |
external oil line gauge hookup need ideas
have a problem of how to best hook up 1/8" oil gauge line to 3/16" existing external oil pipe ?...motor you see has been beefed up a bit with light flywheel ,balanced crank,inserts ,HC head ,cam etc,builder put external oil to timing gear.makes it kind of hard to hookup a oil gauge..ant suplliers that ahve a large selection of brass fittings that may work ? see photo.. thanks for help in advance.
06-16-2015, 11:35 AM | #2 |
Re: external oil line gauge hookup need ideas
First question is "why the external oil line to the timing gear?
Having said that, put an 1/8" pipe "T" in the line right at where it exits the block. One side of the "T" can go for your oil line, the other side to your pressure gauge. Should be able to get whatever brass pipe fittings at your local hardware stores, plumbing & heating, hydraulic suppliers.
06-16-2015, 12:53 PM | #3 |
Can't find a tee with 3/16" one end and 1/8" other ..two different sizes of pipe involved here ..guess I did not make that clear in first post...oil gauge is 1/8" from supplier while existing external line 3/16"
06-16-2015, 01:19 PM | #4 |
OK, so the hole in the block is 1/8" NPT. Get a "T" that is 1/8" NPT like the one pictured below, screw it into the block. On one leg of the new "T", screw in your oil line. On the other leg of the new "T" screw in your gauge line.
06-16-2015, 01:46 PM | #5 |
I would remove and plug the hole at the timing gear and then add the oil gauge where the line was at the block. The gears get oiled from the valve chamber anyway.
06-16-2015, 03:07 PM | #6 |
Sometimes I want to say ,,You should have bought a Shay. |
06-16-2015, 03:15 PM | #7 |
I'd pull the valve chamber cover first before thinking about doing this to see how the builder plumbed the oil delivery.
06-16-2015, 03:32 PM | #8 |
06-16-2015, 08:44 PM | #9 |
I have a full pressure system and this is how I connected mine.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
06-16-2015, 09:48 PM | #10 |
Thanks for replys ..T think.. CARLG ..has the answer I was looking for one line is 3/16" and the other is 1/8" I guess I can find a nut of each size pipe at 1/8 pipe thread into the block..sc
06-17-2015, 05:10 AM | #11 |
06-17-2015, 06:22 AM | #12 |
I would also remove the line to the timing gears, however I would still connect the oil pressure gauge. I have my oil pressure gauge connected to my stock A motor and when the oil is cold in cool mornings I am able to see up to 4 lbs. pressure even though it reduces to almost zero when it warms up. At least it would give me a heads up if It read zero on cold mornings, to at least check the dipstick.
