12-24-2014, 02:55 PM | #1 |
What is this collar for?
I can't figure out what the purpose of this collar on the starter rod is? Is it some sort of stop? Has a allen head set screw. Haven't seen it on other cars.
Thanks... And Merry Christmas to All... |
12-24-2014, 03:36 PM | #2 |
Re: What is this collar for?
It looks like the h2o pump collar? Ditch it.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
12-24-2014, 03:49 PM | #3 |
Is there a hole drilled to accommodate the set screw through to the starter rod shaft? If so perhaps the shaft is not threaded, and it was a farmers fix to retain the starter rod.
Or "to facilitate the next garage fire" |
12-24-2014, 05:21 PM | #4 |
It looks smaller than a water pump shaft collar. Maybe they jist thought it looked purty .
12-24-2014, 05:29 PM | #5 |
Very interesting I wouldn't due anything it will cause people to ask "Q"
12-24-2014, 05:50 PM | #6 |
12-24-2014, 06:27 PM | #7 |
That is a very rare accessory item for model A's.
It is a cardinal grammeter and it is used to bleed off the excess inverse reactive current from the starter. |
12-24-2014, 06:38 PM | #8 |
Should fetch a pretty penny on ebay.
12-24-2014, 06:55 PM | #9 | |
I guess it could be any of the above, haha. So basically I don't need it... Another mystery solved. |
12-24-2014, 06:57 PM | #10 |
12-24-2014, 10:38 PM | #11 |
Maybe it adds weight to the starter rod so his wife did not have to push so hard to get it started.
Fred Kroon 1929 Std Coupe 1929 Huckster |
12-24-2014, 10:42 PM | #12 |
[QUOTE=Y-Blockhead;1003814]I can't figure out what the purpose of this collar on the starter rod is? Is it some sort of stop? Has a allen head set screw. Haven't seen it on other cars.(QUOTE)
leave it, it's supposed to be there, everyone else's is missing |
12-25-2014, 12:21 AM | #13 |
You are the mystery solver U blockhead
12-25-2014, 07:05 AM | #14 |
It is installed backward
12-25-2014, 10:10 AM | #15 |
never seen one Cad..........mines is raven finish!
12-25-2014, 10:18 AM | #16 |
How about maybe the rod would unscrew so the person put that on to keep it from unscrewing.
12-25-2014, 10:24 AM | #17 |
Looks like this guy has lots ideas. Look at the double nuts on the starter cable. When things get just right, I think it could make a nice fire when that collar hits that big nut.
I bet the rest of the cars has some nice improvements also. |
12-25-2014, 10:56 AM | #18 |
I wonder if the collar was put there to make it easier starting/turn-over the motor from inside the engine compartment. You could wrap your fingers around the collar a lot easier than just the rod itself.
Just thinking! (Which sometimes can be dangerous.)
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
12-25-2014, 11:04 AM | #19 |
Haha, Always somebody with the negative.
The Master Cylinder Enjoying life at the beach in SoCal... |
12-25-2014, 11:50 AM | #20 |
Now, that's the only one that makes sense, and I'll bet you are right.
