11-06-2014, 04:15 PM | #1 |
1932 Radiator Shell and Grill Question
Does this bolt on to a model a easily or ? Thinking of making one. Thanks for the input
11-06-2014, 05:13 PM | #2 |
Re: 1932 Radiator Shell and Grill Question
Good question for HAMB. First I assume you mean a '30-'31 Model A. If you have a '28-'29 my suggestion would be to forget it. On the '30-'31 you will find that the radiator neck is in the wrong location and has to be moved or cut off and another inlet installed under the hood. The hood hinge will have to be dealt with as the Model A is a rod and the '32 is a formed stainless steel strip.
Charlie Stephens |
11-06-2014, 07:11 PM | #3 |
You may also want to check with the Rootlieb Company.
11-07-2014, 12:50 PM | #4 |
It will bolt on to the 30-31. Just use the front hinge retainer for the Model A shell so the Model A hood fits.
http://www.macsautoparts.com/ford_mo...ess-steel.html Last edited by LeroyM; 11-07-2014 at 12:58 PM. |
11-07-2014, 01:12 PM | #5 |
My '32 shell is a repro from Drake and has no holes nor clearance to mount the A front hood hold down as suggested. There are two holes about 3" down the shell on both sides but you have to fab up a strap to go from the holes to mount the A hold down.
11-07-2014, 03:19 PM | #6 |
and is v shaped headlight bar to 30-31 model a that is built for 1932 radiator Shell is needed?. or will original 1931 headlight bar fit? thanks..
i'm stuck in norway |
11-07-2014, 07:18 PM | #7 |
Need a headlight bar for your application. Straight won't work.
Paul |
11-07-2014, 07:30 PM | #8 |
Check to see if someone makes a lower splash apron that fits the '32 shell and A fenders. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
11-07-2014, 09:55 PM | #9 |
The '32 commercial grille is a virtual bolt-on to a 30-31 radiator. Only modification needed is to fab/re-drill the lower shell-to-radiator bracket.
The '32 passenger grille doesn't fit as well because the lip for the insert is too deep. This causes alignment issues with the radiator neck. In either case, you'll need to modify the headlight bar to fit, as it will hit the grille bars. |
