Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default 63 260 Trans
I've recently acquired a nice 63 fairlane s.w. with original 260 eng./A.T. The eng.is sound,the trans is junk. What else will fit? I prefer auto. Thanks J.B.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: 63 260 Trans
A C4
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
ford changed the bellhousing bolt pattern around 1964 or 65.a c4 has a removable belhousing so if they are both c4s you may be able to swap bellhousings.
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
Use a later model C4, just switch bell housings, assuming you already have a C4. The post 71 C4s have a better design, and rebuild kits and shift kits are readily available (although ALL C4s are good trannys)If you have the Two speed auto, you will need a pre 1965 C4 bell housing (I have several)and possibly a matching 260 C4 flywheel. A good C4 would be a 302 Mustang II, which had a deeper sump pan and will hold more fluid.
