Old 07-14-2014, 07:11 AM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default Yes, they are still out there NUMBER 2
Drug another Car out of storage (barn) that was parked in 1982, picked up a 1939 Sedan Lincoln Zephyr. Ceiling was starting to fall down and rock wool insulation and pieces of sheet rock had fallen on top of car. All the tires were flat, I took air compressor and aired up. Took four of us to roll car ( very heavy compared to early V8's and model A's ) Pulled up in trailer with winch and home we came, unloaded Saturday evening and had several people came over and inspected old car. Yesterday afternoon I removed plugs and put automatic transmission fluid in all cylinders ( 12 ) and let set until late evening. My son and I went to garage and I placed car in 2nd gear and we rocked car, got the engine to turn over. I also drained oil and put a gallon of diesel in car and will drain out today. Going to remove carb and distributor and clean/inspect/lube. Still have not got trunk open, no key, locksmith maybe today, hope full of 39 silver dollars!!!! Will go for a start later this week.
home in OHIO
Original heads and have additional intake, several carbs came with car
Have air filter, fender skirts, extra wheel drum, and coil.
Bruce in southern OH is offline   Reply With Quote
Old 07-14-2014, 07:24 AM   #2
oldford2
oldford2's Avatar
Default Re: Yes, they are still out there NUMBER 2
Great Find!!!!!!!
oldford2 is offline   Reply With Quote
Old 07-14-2014, 07:31 AM   #3
Fibber Mcgee
Fibber Mcgee's Avatar
Great find. How much did it set you back?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 07-14-2014, 07:38 AM   #4
mfagan
mfagan's Avatar
Looks like a nice solid car..keep us posted on the start up.
mfagan is offline   Reply With Quote
Old 07-14-2014, 08:33 AM   #5
Admiral
Admiral's Avatar
WOW, what a find! Looks great. Keep us posted on your progress...
Admiral is offline   Reply With Quote
Old 07-14-2014, 08:35 AM   #6
Lawson Cox
Lawson Cox's Avatar
awesome find. Congratulations.
Old 07-14-2014, 09:01 AM   #7
cmbrucew
cmbrucew's Avatar
Good you found it when you did. Not much damage.
Will make a great driver.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-14-2014, 09:02 AM   #8
Willit Stop
Willit Stop's Avatar
The next time you go barn shopping,take me with you. Very nice!
Willit Stop is offline   Reply With Quote
Old 07-14-2014, 09:21 AM   #9
Tim Brown
Tim Brown's Avatar
Excellent find! I hope you and your son have a great time with this one. Congrats
Tim Brown is offline   Reply With Quote
Old 07-14-2014, 09:27 AM   #10
mhsprecher
mhsprecher's Avatar
I hope you can see that we are all green with envy. A Zephyr is a dream find for me. A couple ideally, LOL!
mhsprecher is offline   Reply With Quote
Old 07-14-2014, 09:33 AM   #11
Samson
Samson's Avatar
Bruce,
You keep coming up with some very fine cars!!!
Samson is offline   Reply With Quote
Old 07-14-2014, 09:54 AM   #12
Vic Piano
Vic Piano's Avatar
Bruce, that is outstanding!!!
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 07-14-2014, 10:04 AM   #13
waterboychuck
waterboychuck's Avatar
Nice find. Would like to see more photos once you wash it.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 07-14-2014, 01:39 PM   #14
FL&WVMIKE
FL&WVMIKE's Avatar
BRUCE ....................
You didn't stage (fake) that did you ?
Nice find.
Congratulations !
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 07-14-2014, 02:46 PM   #15
MIKE, no afraid not, still in garage unwashed today, have not cleaned up but will tomorrow and wipe down with some Gibbs oil if I can find a can I had. I need to find some of those old plastic seat covers that were period correct. ( like your grandmaw had on her couch ) I am going to get running first. I did remove the carburetor today and it has the Zephyr symbol on bowl. Also removed the coil and found that one of the carbon tips is missing, do not know if it fell off as I gentle lifted off distributor or it went bad over the years. The distributor caps are stuck in the sides of distributor, now I will have to remove generator and spark plug looms to get everything out together so I can tap with wood to un stick. Then I will have to sand down caps so they will go back together. (old material swells) Need to have carb rebuild ( rubber products ), fuel pump for new fuel, and coil. Need suggestions for all three again, bubba? Henry? who is still out there? I am working now on trying to get plug out of gas tank, looks like I might have to fill with water and drill to remove plug from underneath. Is there a plate in floor of trunk for tank sending unit? Locksmith did not come today, need trunk open! Also, intake gasket, after I take spark plug looms off I am going to take intake off and look at valley and oil up everything before I start. Will look at brake master cylinder soon. thanks Bruce
Old 07-14-2014, 02:54 PM   #16
Vic Piano
Vic Piano's Avatar
Bruce, you've got your fun cut out for you. I would suggest the following, for the carb, Charlie NY, for the distributor, Bubba's and for the coil and water pumps, Skip Haney. You should also check out www.LZOC.org, the Lincoln Zephyr Owners Club. They have an excellent Vender's list for parts & services related to Lincoln Zephyrs. Good luck on an excellent project. Vic
Old 07-14-2014, 03:38 PM   #17
Mike B
That's like asking a lady how much she weighs, or how old she is
Mike B is offline   Reply With Quote
Old 07-14-2014, 03:52 PM   #18
Bolts
Bolts's Avatar
That car looks practically new Bruce! Fabulous.
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 07-14-2014, 07:38 PM   #19
Fe26
Very well done, congratulations
Fe26 is offline   Reply With Quote
Old 07-14-2014, 11:26 PM   #20
Fibber Mcgee
I've done that as well.
