07-09-2014, 07:26 PM | #1 |
1931 Roadster Seat Back bottom brackets
Does anyone have the dimensions or a source for the brackets that attach the bottom of the wood for the back of the upper seat cushion to the floor panel?
I understand these are not currently being reproduced. |
07-09-2014, 07:37 PM | #2 |
Re: 1931 Roadster Seat Back bottom brackets
Is this what your looking for...with the 3 clips? Make sure you thank Marco!
07-10-2014, 05:11 AM | #3 |
Yes, thank you, those are the clips.
I can probably make them up based on the photo, but it would be helpful if someone has the dimensions. Anyone? |
07-10-2014, 09:35 AM | #4 |
Call ......www.modelastore.com Bert's in Denver (Colorado)....
and ask for Steve, they may have them. Also, at the top of the main page is a "sticky" that has loads on information to help...try it, it's good! |
07-10-2014, 11:17 AM | #5 |
I had the same problem when I did my 30-31 standard roadster. A guy that posted on the forums that has since passed, made a set and sent them to me for free, screws, washer, nuts and all. I should have took measurements before I installed them. As it is, I would have to remove some parts to even see them.
07-10-2014, 01:39 PM | #6 |
07-11-2014, 09:16 AM | #7 |
Hi, heres the diamentions the L bracket is 2-78in. long x 2-18in. long on the 2-7/8 in side there are 2 holes ,1-4in. the first is 1-1/16in from the end then 1-5/16in on center. the other side has one 1-4in. elongated hole starting 1-4in. from the top end and is 2-1/8 in. long. If you send me your e-mail address I can send you a pic. good luck THE HOOCH
07-11-2014, 09:20 AM | #8 |
See if u get this
07-11-2014, 10:18 AM | #9 |
Thats good info that I've never seen posted here or anywhere else. That should be helpfull to others in the same boat!!!
07-11-2014, 03:03 PM | #10 |
Hooch,
Wow, great information. Thank you so much! That's exactly what I need. Photos were great too. Dan |
07-11-2014, 06:50 PM | #11 |
Okay,...they look like they should work....but I have some questions.
These questions coming from a 28-29 guy, about 30-31's. 1. Were the originals bolted in or riveted? 2. Whats with the extra hole in front of the bracket...is that the original hole for the bracket? 3. No shot intended, but the brackets look like the came from the hard- ware store.....is that what there supposed to look like? Last edited by d.j. moordigian; 07-11-2014 at 07:01 PM. |
07-13-2014, 07:10 PM | #12 |
these brackets were attached to the seat back when I bought the car, my car was only a shell but one of the parts that came with it was an original seat back frame and these were attached to it . they were rusty so I blasted them and painted them black. the extra hole u see is my mistake and still needs to be corrected. hope this helps you out. THE HOOCH
03-14-2024, 10:46 PM | #13 |
Trying to remove the roadster’s seat back so I can re-upholster it. How is it meant to be removed? The bottom of the driver-side released with great difficulty but I cannot get the passenger-side unstuck. What should I try? I struggled with it for 3 or 4 hours today to no avail.
David in San Antonio 1930 ('31?) Deluxe "Wretched Roadster" Restored 1957 Alamo A’s Club |
