Go Back   The Ford Barn > The Archives > Early V8
Old 03-29-2005, 04:05 PM   #1
Guest
Posts: n/a
Default 34 Ford Front Brakes
O.K my drivers side front brake housing assembly came apart beautifully and the operating pin slid out downwards with no problems. Now I cannot seem to remove the front brake operating pin from the passenger side is there a special trick that I'm missing here? I've tried pulling it downward, unscrewing it, wiggling it and next I was going to beat on it but I knew that was not the answer although I felt like it. So what am I doing wrong????
Old 03-29-2005, 08:20 PM   #2
Guest
Posts: n/a
Default Re: 34 Ford Front Brakes
You mean the actuating rod inside the king pin/spindle pin is preventing you from removing the backing plate from the stub axle/spindle?
If so, disconnect brake rod actuator from the axle mounting & remove it from the kingpin/spindle pin & try again.
Old 03-30-2005, 02:33 AM   #3
Guest
Posts: n/a
Brian, that is exactly what I mean and I will try it tonight. But why did I not have to disconnect the brake rod actuator on the drivers side for the actuating rod inside the king pin just slid nicely out and when I reassembled the brakes they functioned just fine.
Old 03-30-2005, 08:33 AM   #4
Guest
Posts: n/a
You were'nt holding your tongue right!
Possibly the adjuster was backed off further or the rod adjustment was looser?
Brian NZ
