05-26-2014, 11:58 AM | #1 |
Pros and cons of swapping model A distributor with model B
I've looked hi and lo on the site to find the pros and cons of using a model B distributor and I must be using the wrong search terminology. Anyway, can someone educate me on the pros and cons of swapping my model A distributor with a model b stock distributor? Thanks, Glen
05-26-2014, 12:24 PM | #2 |
Re: Pros and cons of swapping model A distributor with model B
All you have to do is type in model b dist , in the search at the top of the page and 239 threads show up .
Sometimes I want to say ,,You should have bought a Shay. |
05-26-2014, 12:44 PM | #3 |
05-26-2014, 12:53 PM | #4 |
Thanks Bob
05-26-2014, 01:08 PM | #5 |
I first got a B Dist a while ago and was eager to hook it up. I was just too busy, but I read everything I could about it and after reading all of it, I came to the conclusion it was much ado about very little. Someone said the B dist. doesn't advance enough. Others pointed out the problems with the B's timing gear cover. Those are the main "Cons", what's the Pros? Is there any? Lotsa fitutzin just to get rid of the timing lever!
Terry |
05-26-2014, 02:04 PM | #6 |
05-26-2014, 02:29 PM | #7 |
Hi Glen,
FWIW, lots of technical information already posted on Model A Forums; however, just one pro & con opinion after many years of successfully trying & swapping out both. 1. A vs. B Distributer: a. Both can perform perfectly if one knows what he/she is doing. b. Maybe a comparison would be like, with an A distributor, if you can really play a fiddle in a band, go for it & play it; however, if you have slight difficulty playing the fiddle, (like adjusting the A spark advance distributor timing), just insert a CD in your player to listen to fiddle music without playing it ...... likewise, install & allow the B distributor to do the different fiddling & proper timing for starts, low speed, high speed, & climbing steep inclines. c. B distributors properly timed can also be great if you occasionally allow slightly uninformed others to both start & drive your Model A. As compared to manual spark advance A distributors with inexperienced drivers, with automatic timing B on properly timed distributors ........... absolutely no worry about broken starter springs or attaching bolts; no friend's or children's broken arms if hand cranked; & no Babbitt bearing pounding all which can easily be caused by inexperience operators with improper manual timing. d. In very heavy urban stop & go traffic, rather than fiddling with a spark advance lever, allow the B distributor to advance & retard timing for optimum performance at all RPM's & quicker properly timed pick up ability. e. B distributors have been & may still be criticized by Model A purists as not being authentic; however, if found in this predicament, if you like, just carry a spare A distributor to change out in minutes to avoid having to witness multiple Model A purists heart attacks. f. Maybe for extra protection, if not enough time for a quick distributor change out, also carry a folding ladder so if crucified for having a B distributor, somebody can climb up & take you off of the cross. g. In the mean time, at this time in life, with my 3 sons & a daughter possibly driving now & then, the B distributor stays on & I don't have to remind them of anything. |
05-26-2014, 04:16 PM | #8 |
Than you, this helps a lot. Glen
05-26-2014, 04:37 PM | #9 |
For better performance than the B distributor can give, I installed Mallory dual point distributors in two of our model A's. My girls don't have a bit of problem with the Mallory distributor. The Mallory dual point distributors have been the most trouble free distributors that I have ever used with any engine.
05-26-2014, 04:46 PM | #10 |
I have a brand new Mallory dual point, YL 11A2 that I got with a bunch of parts I bought. It's never been installed. Are parts hard to get for them? How would I set up the timing? Anything else I should know. Glen
05-26-2014, 05:39 PM | #11 |
Hey Glen- Come drive my CCPU with B dist. when you bring your speedster over.
05-26-2014, 07:18 PM | #12 | |
The only part that I have ever needed with my Mallory distributors was the condenser. I am using Ford V8 condensers with mine., the same condenser used with the so called modern points that the model A venders sell.. Bubbas ignition has Mallory parts but I don't have an address or phone number. I got my first Mallory distributor from Harrys model A parts in Oregon in the early 90s . Harry told me that They had run these distributors for over 30.000 miles without having to do anything. Mine have been trouble free. This is the distributor that was used in the dyno tests with the Brumfield heads back in the ninties. The dual point Mallory was shown to give horsepower increases at low to mid RPM range. I had installed float-A-motor mounts in the coupe and there was quiet a bit of cl;utch chatter when taking off. After installing the Mallory distributor, the chatter went away completely. I was talking to Ken Miller and he felt that the Mallory distributor advanced so smoothly that it removed the chatter. Just an example of the smoothness of the advance. |
05-26-2014, 07:57 PM | #13 |
Thanks Guys, will do Jim, see you tomorrow if it doesn't rain.
05-26-2014, 09:03 PM | #14 |
Do you still get taca-taca-taca-taca with the B dist.?
05-26-2014, 09:34 PM | #15 |
05-26-2014, 11:19 PM | #16 |
Posted about my B just about 3 days ago and my positive experience.
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
05-27-2014, 01:04 AM | #17 |
Glen,
FWIW in case you missed some of the Model B information in Forum "Search": 1. One caution with a Model B distributor is that the upper bronze bushing for the center rotating distributor shaft always blocks the horizontal round oil path from the side of the distributor to the center rotating shaft; hence, for providing correct distributor shaft oil lubrication, one must remove the spring loaded cylindrical oiler located on the side of the B distributor & drill a small hole in one side of the installed bronze bushing so oil can reach this vertically positioned rotating shaft. 2. Also, some of the Non-Ford vintage printed Motors Books of the 1930's era recommend that Model B distributor points be adjusted to have an 0.018" gap; however, Ford's original 1932 Model B manual recommends that the ignition point gap be set at between 0.018" to 0.022". 3. Appears better to always set the contact points at the greater recommended gap dimension of .022" so when the point's non-ferrous lug wears a little when resting on the lubricated, rotating Model B distributor cam, with later slight wear, the point gap will only close to maybe 0.020" or slightly less, & still meet Ford's recommended point gap setting of 0.018" to 0.022". Hope this helps. Last edited by H. L. Chauvin; 05-27-2014 at 01:11 AM. |
05-27-2014, 05:42 AM | #18 |
Thanks H.L.
06-13-2014, 03:54 PM | #19 |
I used Nu-rex handle to time my model B distributor on my model B engine but it's not perfect. My engine run smooth but no high rpm.
06-13-2014, 04:13 PM | #20 | |
Good luck! |
