04-27-2014, 10:13 PM | #1 |
Extremmly High Oil pressure in a 1952 Ford Flathead all of a sudden?
Would a broken Pressure relief spring cause High oil pressure readings and a knocking sound?
04-27-2014, 10:32 PM | #2 |
Re: Extremmly High Oil pressure in a 1952 Ford Flathead all of a sudden?
Never seen a broken spring. And if it was broken, it wouldn't cause a knock. Need more of a description.
04-27-2014, 11:25 PM | #3 |
A weak spring lowers the pressure, a broken spring should be real low.
Use a mechanical gauge to check the pressure. How high is it?? I'm thinking real low pressure and a bad gauge. G.M.
www.fordcollector.com |
04-27-2014, 11:54 PM | #4 |
a couple of things come to mind, a bad gage or a stuck relief valve in pump, but as far as i know neither will cause a knocking sound, is it a sharp knock or a deep knock?
04-28-2014, 12:12 AM | #5 |
Blocked oil gallery?
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
04-28-2014, 06:48 AM | #6 |
04-28-2014, 07:58 AM | #7 |
I also have erratic oil pressure reads. But you can't even hear my car running. It is quiet. Nothing leaks out of my car. The car runs at about 170 degrees and does not get hot under normal circumstances. What should the pressure be and how should the gauge act?
04-28-2014, 08:18 AM | #8 | |
Did the pressure guage suddunly go realy high at the same time the knock started?
Martin. Quote:
If its the stock electric guage, these can be far from acurate. Capiliary type are better. There was an old rule of thum, 30lb at 30mph is fine. I replaced the doings inside the oil guage on the truck, and fitted the guts of a capilary type inside. Looks the same as it did before, but it gives belivable pressure. Martin. |
04-28-2014, 12:29 PM | #9 |
If it spun a bearing on the crankshaft, it might have higher than normal readings until the bearing melts to pieces anyway.
