12-21-2013, 03:25 PM | #1 |
Glass channel installation
Guys,
The glass channels in my '30 Tudor were non-existent when I acquired it, so I'm not 100% positive that I know where I should use foam or if there is another material that is supposed to go in the bottom glass channel. I saw where some guys said use u channel foam so the glass seals against the outside window frame, but I'm not sure I follow exactly what you mean. Does the illustration below show the best use of foam and glue? |
12-21-2013, 03:32 PM | #2 |
Re: Glass channel installation
Give Steve at Berts a call. They have everything you need. On my '28, it was actual U-shaped window channel that went in there.
http://www.modelastore.com Best of luck to you.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
12-21-2013, 11:27 PM | #3 |
I believe that the bottom "foam" does not exist. There is glass bedding with adhesive that holds into the metal frame channel- IMO. At least that is what my fordor now has! There are bumpers at the bottom stop the glass from dropping down further.
12-22-2013, 08:52 AM | #4 |
also 3m sells a 2 part epoxy style channel bonder but you need a special dual piston gun to apply it unless you cut open the tube and manually mix the two together |
