10-19-2013, 08:11 PM | #1 |
Cabriolet 68B top iron screw length
I am looking for the correct length for the 1/4 20 TPI screw that holds the front header to the top iron. There are three screws on each side.
thanks
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
10-19-2013, 10:48 PM | #2 |
Re: Cabriolet 68B top iron screw length
Mine have been replace but measure 1 1/4" just long enough to screw into the plate. hope this help.
10-19-2013, 11:08 PM | #3 | |
Thanks quickchange, mine have been replaced and I was hoping to get a length for an original screw.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 10-19-2013 at 11:20 PM. |
10-24-2013, 06:35 PM | #4 | |
This started based on a comment from John Hash when he saw my Cabriolet. He could see the top material was being pushed up from the screws being too long. I reached in between the top material and top header and could feel the thread protrusion. I removed the screws and they were 1 1/4 in long. I ground the screws down to a length of 1 1/8 reinstalled them. I then reached in between the top material and top header and found that the thread protrusion was now eliminated. I hope this helps other Cabriolet owners avoid this minor problem.
10-24-2013, 07:17 PM | #5 |
