09-26-2013, 01:20 AM | #1 |
Which way does the windshield gasket go in?
Which side is in and what is out?
Matt in Seattle |
09-26-2013, 08:36 AM | #2 |
Re: Which way does the windshield gasket go in?
looking at it the way you are holding it the surface that your finger is on go`s towards the front of the windshield. after it is installed the seal should lean back towards the body to make a good seal. if you put it backwards it will not seal at all.
09-26-2013, 08:39 AM | #3 |
My mistake.........I was thinking of the windshield hinge rubber.
09-26-2013, 06:12 PM | #4 |
You are correct, I was thinking about the hinge rubber
09-26-2013, 06:44 PM | #5 |
